Question about Acer Computers & Internet
Acer Aspire T300 takes several hours for light on start up switch to come on and then the computer will then boot up okay. Have to keep the computer on all the time so that I don;t have to wait all this time to start the computer, Should I have the power supply to the mother board replaced?
    Scholar:
  • 57 Answers
My first thought is that you are right. My second thought is that your computer is probably a couple of years old and some power supplies will wear out. Especially if there's a lot of dust bunnies running around. I'd first take a vacuum to it. Put the vacuum right on the fan of the power supply and let it spin it up, then move it to a spot opposite to that. If you can, remove the case side and vacuum inside as well. Get all the nooks and crannies, but be careful you don't knock anything loose. No guarantee it will help, but it just might.
Posted on Dec 02, 2008
My Acer Aspire will not boot and I don't have enough memory to fix it
Try a system restore to the last good boot. This has happened a few times with my acer and you just have to go back to a moment when your computer was okay. Other than that try a refresh which means installing some apps again. System restore is probably your best optio if it is turned on. Also try msconfig from the system prompt or boot into the administrator account start a new account and try to deal with the problems there with antivirus antimalware or both. If you made a boot disk try booting from that and turn off stuff in msconfig.
Good Luck I know it sucks.
Aug 23, 2014 | Acer Aspire Computers & Internet
Acer Notebook want boot up
Hook a spare monitor to the video output usually on the back, if okay! the inverter board just below the screen is most likely the problem, or the backlight behind the display. But if both show the same issue it is the video graphics card normally built into the motherboard.
Apr 26, 2012 | Acer Aspire One PC Notebook
Which F key do I use to reformat my Acer Aspire One A 150 netbook?
Hi and welcome to FixYa!
The first thing you need to do is save all of your pictures and files that you have on your computer to your email or upload them to another account that stores them. When you factory reset an Acer, it wipes it clean of everything you have downloaded on it. THIS IS PERMANENT ONCE FACTORY RESTORE IS DONE.
Turn your computer off.
Restart your computer.
When the Acer screen comes up, press and hold Alt+F10.
Keep pressing F10 repeatedly while keeping the Alt button pressed down.
You will be asked how you want to reset your computer.
Press Factory Restore.
This may take up to an hour.
If you are asked to enter a pass code, enter your pass code or 000000.
Hit okay.
If this solution was helpful, please rate!
KittyTech
Nov 15, 2010 | Acer Aspire One A150-1006 Notebook
My Acer Aspire 5520 blinks the power light when I turn it on; it will not boot up.
It looks like your battery is either discharged or has a short circuit.
Plug the power AC cord in the laptop and let recharge the battery at least 3 hours before you try to start it again. If the computer boots up, enter the BIOS and check to see if you have a "battery check" oprion. If you do, start it and let it run until it is done (it may take several hours to complete). It will check the battery charge cycle.
Mar 22, 2010 | Acer Aspire 5520-5908 Notebook
My computer comes on but the monitor keeps
check the resolution.
start up through safe mode(F8 key before boot-up), and reduce the resolution.
Feb 11, 2010 | Acer Aspire m5640 PC Desktop
Acer aspire one, won't wake up from sleep mode, screen blank
I'm having the same problem, but I don't want to have to turn off my computer EVERY time it does this. (I have not been able to shut down the laptop normally because it goes into sleep every time.) I've heard that after 3 hours it builds up an eletrical charge and you have to take the battery out, but I havn't had it on for 3 hours at a time.
Oct 25, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5640 Desktop won't boot.
when you turn on the system hit the F8 button several times and boot in safe mode and uninstall the wireless card or run system restore and take back your system to an back date
Sep 04, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5920 - Acer Arcade Deluxe Problem
have you checked your bios settings are you booting from the right drive have you tried recovery?
Jun 02, 2009 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5100 wont start up correctly
Try removing the battery and connecting the AC adapter then see if it boots up.
Reinstall the battery and keep the AC adapter connected and see if it boots up, if so leave it charge the battery for several hours.
If none of these work, get a replacement as there is a more segnificant problem.
I hope this helps.
Good Luck.
Mar 14, 2009 | Acer Aspire 5100-5033 Notebook
Acer t300
Open the case ( i take it your warranty has expired ) and check all connections, unplug the wires from the powersupply and plug them back in, when you try and switch it on, do any of the fans start spinning.. you probably have a dead CPU of motherboard..
Determine what CPU you have and borrow the same socket type from someone else if you can, slot it in and check, works = dead CPU
Good Luck
Mar 19, 2008 | Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
