Question about Gateway Computers & Internet
System says that it doesnt detect a hard drive,
It also states to make sure the drive is powered up. How do I determine if the drive is getting power, or if the drive has gone bad. The laptop is only a couple of years old.
  • Gateway Master
  • 4,806 Answers
Go into the bios to see if the drive shows up there, if it doesn't then the drive has failed
kind regards and please don't forget to rate us
Posted on Dec 02, 2008
Laptop not working. says disk read error occurred. tried ctrl+alt+delete but saus phoenix secure core (tm) set up itility and enter pass word. I dont know the psss word.
What you have seems top be one of two issues, plus the password problem. Either the hard drive has malfunctioned in the laptop and the OS cannot read the disk to boot up, or possibly the BIOS/CMOS has "forgotten" where the boot device is. This can happen if there is a low CMOS battery event. In either case the laptop will revert to the BIOS/CMOS to allow the user to check settings and determine if the hard drive is being detected by the system. Unfortunately, it appears that someone has placed a BIOS password on your machine. These are not easy to get around. The only sure way to remove it is to disconnect the power cord, remove the battery, access the interior of the laptop, and remove (or unplug) the CMOS battery. Once you have done that, press and release the POWER ON button several times. This will discharge all power in the CMOS circuit and the CMOS will reset to factory defaults (no password). Then plug in or reinsert the CMOS battery, close the case, replace the battery and plug in the device and restart the system. You should then be able to access the CMOS. If the CMOS detects the hard drive on the main page, check the boot device and boot sequence menus to be sure that the HDD is the first device for bootup. If the HDD is not detected, or if the HDD is detected and all settings are correct and you still cannot boot to the drive due to the read error, you may need to replace the hard drive. If you have the recovery disc or an original OS install disk, you may be able to boot to it and attempt a repair install, where the system will try to fix whatever happened to the OS. If there is simply a corrupt file, the repair install may fix the issue, If the error in a physical one in the system area of the hard drive, you may be out of luck.
Nov 02, 2016 | Computers & Internet
My pc doesnt load every time I want to turn after i boot the power and press 1st, 2nd, 3rd and 4th boot... in the screen I can see Dell is loading but doesnt move, i try to press F12 for boot and the...
Are you Sure that the computer model is Dell Optiplex GX260? Because looking at the manual diagnostic lights are found at the back. and the fault can be determine If the ABCD lights are yellow or green. But None the less 2/3 Depicts a hard drive problem while 3/4 depicts a memory issue.
Hard drive Issue:
1. Disconnect all non essential cables at the back of the computer. Leave only the mouse, monitor and keyboard. See if it boots up normally
2. If it boot up fine. try plugging one peripheral at a time until you find which peripheral causes the computer not to POST (Power on Self Test)
3. If you still getting problems, Follow these steps
4. To access the BIOS you must tap F2 or delete key upon turning the computer on
5. Try to look for the Hard drive if it is detected by BIOS if not got to step 9
6. Look for Boot Sequence or anything that is associated Boot
7. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
8. Save the changes and Restart
9. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
10. If Step 9 did not work I think you need to replace the Hard drive
Memory Issue:
1. Open the chassis of the computer
2. Try taking out all memory modules
3. Rub the metal contacts of all memory with a pencil eraser
4. If more than one memory. Put one memory first and turn the computer on. If it turned on add another memory and turn the computer on. Repeat these steps until you determine which memory is faulty or all memory module contacts needs cleaning
Jun 16, 2011 | Dell OptiPlex GX260 PC Desktop
Have an older T23 IBM Thinkpad. Was running Malwarebyts which I just loaded on the system due to a problem at work and wonted to make sure i was ok at home. System ran for aprox 32 min and apeard to lock...
This is a possibility, the T23 is a very old laptop.
Normal 0 Check the BIOS to see if the hard disk is detected, if not open then re-seat the hard drive.
If the BIOS does not detect this hard drive, then the hard drive is probably faulty.
If it was me, I would not waste my time and money trying to get a new hard drive for this ThinkPad.
Disk drive manufacturers do not make small capacity hard drive anymore and the current range of hard drives won't work in your ThinkPad because the BIOS cannot support these hard drives.
Oct 02, 2010 | IBM ThinkPad T40 2373 Notebook
Not detecting the external hdd 120gb wd
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the harddrive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your harddrive, and right click on it.
Then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your harddrive to be detected automatically.
In case it still doesnt work after trying this, then do this:
Unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Nov 25, 2009 | Computers & Internet
Hard Drive Detected
Recheck that both the power supply and the ribbon cable are connected to the drive. Then, if you have it set up that the position on the ribbon cable determines the drive letter, it should show, if this is not selected, you need to ensure the jumper on the hard drive is selected to either master or slave.
Aug 10, 2009 | Computers & Internet
Hard Drive not detected
If you are sure that the disk is okay, then I do suspect it is a power problem. Laptop USB ports often can not provide as much power as desktop USB ports. If possible try using an external power adapter with the disk and see if that works.
You can try some other external hard disk troubleshooting ideas, but probably it is the power.
Jun 10, 2009 | Freecom (24358) 160 GB Network Hard Drive
Boot won't read
Operating system not found. Check hard drive for loose connection power and interface. Reseat it to be sure (power cord disconnected and unit totally turn off before you reseat it).
Go to Bios setting check whether hard drive is been detected or re-detect it to refresh. If harddrive is not detected. Check again for loose wiring. If now detected, reboot it should until the end of operating system loading.
If it say again " requires sytem disk" ,corrupted OS --- repair or reinstall.
Apr 08, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
first let the motherboard detect your hardisk, if the motherboard detects your hardisk, that means that your hardisk is just ok, then pull out the memory of your mobo and clean it out with a pencil eraser, then turn on your computer, if the problem still the same, pull out the processor also and clean it with a pencil eraser also, and insert back the processor to its proper place, then turn on your computer, if the problem is still the same, just repair or reformat your hardisk by using a windows installer, and make a backup of your files that are important. hope this help
Good luck
Jan 28, 2009 | Computers & Internet
Hard drive
Make sure your jumpers on your hard drive are properly set. Also, test another cable to rule out that your IDE cable hasn't faulted. You can also go into your bios settings on startup and check to make your hard drive is detected, if not run the auto detection and see if it is seen then.
Nov 18, 2008 | Dell Dimension 8400 power supply ** FREE...
Ibm thinkpad 390
This issue showed that the harddrive is not found. Try to fixed hardware connecting from harddrive and the board.
did you see hard drive detected in the bios at start? if your are sure that the connection cable is firmly fixed and the hard drive still not detected by the bios. so there is a problem with your harddrive. you should/may replace that.On the other hand if in case your hard drive is detected and still thesame problem encountered. then, you should reinstall your operating system by inserting the original operating system recovery/ windows bootable installation disc to refresh the state of your system.
any problem srising this solution please notify me.
Jan 23, 2008 | IBM ThinkPad 390 E Notebook
Computers & Internet Logo
24 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
