Panasonic SC-AK78 CD Shelf System
Problem for Panasonic SC-AK78 CD Shelf System
Control board
By sweetness_20 on Dec 02, 2008
Lights are not lighting and the cd changer is not changing
Comments:
Dec 03, 2008
- Thanks for your first opinion! But those are the only two symptoms that i'm having and it was advise that the problem may be the CD changer
Same Problem
Apr 02, 2009
-   mon ventilateur ne fonctionne pas sur SC-AK78 -   lise100
Apr 02, 2009
-   mon ventilateur ne fonctionne pas sur SC-AK78 -   Guest
Solution #1
posted on Dec 02, 2008
Not Rated)
Abrsvcs
Rank: Guru  Panasonic Home Audio  Expert
Rating: 88%, 1821 votes
This is not likely a control board issue. If hte CD changer is "out of timing", this problem can be seen. Are there any symptoms other than "no lights"?
Dan
Comments:
Dec 03, 2008
- The way these systems are set up, the CD changer must be able to return to a "known state" before the system will work correctly. When the unit is powered on, there is a startup sequence that happens including a reset of the changer. If any portion of the sequence fails, the unti will power down. I'm not sure of your model was included in an engineering modification to the loader or not. This unit should go to an authorized Panasonic service center for repair. If this unit has the changer that was modified, it will be modified during the re-timing procedure. This should be a labor only repair.
Dan
Was this helpful?
Yes
No
Popular Solutions for Panasonic SC-AK78 CD Shelf
Questions and Unsolved Problems for Panasonic SC-AK78 CD Shelf
Do you recommend Panasonic SC-AK78 CD Shelf System?
Answer
Answer
I have the Panasonic SA-PM53. Whenever i turn it on it can not disc change, disc check, i cant... (More)
Answer
The unit turns on by itsel, the power went out today and this problem occurs since power was... (More)
Answer
The top tray partly opens and closes at power on. I replaced the changer with a new one still have... (More)
Answer
When i switch ON my CD stereo system Model 'Panasonic SC-AK87' i get error message 'F61'.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic SC-AK78 CD Shelf...:
Top Audio Shelf System Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Audio Shelf System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
