Question about Whirlpool MH7140XF Microwave Oven
Whirlpool over range microwave making clicking noise
Clicking noise coming from the stirrer motor on top - have taken apart & isolated it to that for sure. sometimes becomes intermittent after a few minutes running & sometimes actually goes away but then does same thing when used again after sitting a few hours. does this just need to be replaced? and is there anything other than taken old one out & putting new one in to be aware of? alignment or?
My panasonic microwave runs for 5 seconds and then cuts off.what could be the problem?Thanks,ABE
Posted on Dec 09, 2008
  • Whirlpool Master
  • 9,098 Answers
You just need to replace the stirrer motor and be sure it is "meshing" with the stirrer.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 08, 2008
Gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    Microwave makes sound like something moving inside
    follow this steps and use the VOM , and fix it. God bless you
    1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
    2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
    3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
    4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
    Jun 18, 2013 | GE JVM1490 Convection/Microwave Oven
    GE Microwave (JVM1860CD001) control board buzzes.
    see this causes and fix it. God bless you
    Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
    Exhaust Fan Motor If the microwave is loud when running the fan motor might be
    Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
    Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
    Oct 10, 2012 | GE Microwave Ovens
    Stirrer Motor Part Number PS237771 GE Microwave
    Quite possibly the Stirrer/ antenna motor. To Replace that, the outer cover of the machine must be removed. Unplug unit and take off the screws on the back of the unit and pull the cover back toward you and it will come off. The antenna motor is on the top of the unit and is only held on with 2 screws. You take off the two screws and lift it off of the unit. when replacing it you have to make sure the antenna is properly positioned on the shaft of the new motor to make sure it will turn properly. Not a difficult repair.
    Oct 30, 2017 | GE Microwave Ovens
    My Whirlpool microwave model MH9181XMT started making a loud noise while running (it sounds like a wobbly fan) It continues to heat and run perfectly but with the noise. Any ideas?
    Assuming you already ruled out the exhaust fan there are 2 stirrer motors, one for the turntable and one for the stirrer blades in the top. One of those could be bad. eric
    Aug 05, 2009 | Microwave Ovens
    Microwave pops and sparks when running. Nothing
    in the top of unit is a round cover and damage is coming from here. This is serious and needs to be checked out. the cover contains a stirrer that moves waves around<<circulates them>> in this cavity probably paint is thin and allowing waves to penetrate metal of cabinet. Call manufacturer and see if there is anything they will do for you before taking it upon yourself to either get repairman or get rid of unit.stirrer is probably damaged and cabinet burned from waves.
    Apr 26, 2009 | Whirlpool GH8155XJ Microwave Oven
    A rattling noise
    You have a problem with the microwave stirrer motor. Cost of part is near $90 and will require 2+ hours to get to, exchange and close back up.
    Either get a new microwave of put up with the noise (which I did for 6+ years).
    Nov 18, 2008 | Whirlpool GH8155XM Microwave Oven
    GE over the range microwave making grinding noise
    This sounds like the stirrer. If it sticks or stops, the microwaves can damage or destroy it. You may have a bad stirrer or magnetron. There is an important bulletin that covers these problems. To see if yours is covered, see: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If you need more help, please follow-up.
    Apr 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
    Whirlpool MH7140XF Microwave Oven Logo
    1,203 people viewed this question
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
