Question about GE Superadio III AM/FM
Milwakee job site radio not working
I pluged the radio in, it worked for a sec, then Nothing! To me sounds like a fuse. I took cover off and I cant seem to find the fuse.Was hoping some can help me get this thing working again, I need tunes at the jobsite!! Thanks in advance
  • David Ford
    David Ford May 11, 2010
    What is the Model number and I will see if I can download a schematic and try and help.
  • 4 Answers
There is no fuse, have a look at the transformer.
Posted on Oct 28, 2009
  • tmacarthu38 Jan 15, 2010
    There is also a small terminal block that the "primary" or "feed" wires go to that may be causing an intermittant connection.
Radio wont work
Check to fuse.. there may be one inside
Apr 21, 2014 | Milwaukee Tool Milwaukee 49 24 0280 Radio...
2001 Toyota solara radio dead
why not say what works on radio.
stock radio?
park lamps ,dead , i bet not
all other lamps dead.(dials, etc)?
no sound only?
or tunes stations , i see it tune, scan works but sound is dead
post that, and the operators guide , shows where the RADIO fuse is
mostly in the cab fuse box.
inlines are aftermarket radios' not stock.
does it ask for CODE?
if yes ,the radio codes if not backed is a show stopper
dealer only fix. (big secret) or any certified, lock smith
see my 25posts here on this forum under radio codes
omg, 300,000 hits.
paste this in to the google search box and magic happens.
called a "site search."
radio code toyota site:http://www.fixya.com
Jan 11, 2014 | Toyota Cars & Trucks
My Radio say SEC? I cant start radio
The sec displayed is security code in case radio is stolen it cant be used without entering the code. Owner may have disconnected battery and didnt put a memory saver in lighter outlet so it locked. If you go to dealer they can retrive the code for you then you enter code and radio should work.unless they changed the factory code. If not and code from dealer works keep in car or safe place so you have it. Usually no charge to do retrival at dealer takes 2 minutes. Hope this helps
Feb 20, 2013 | 1995 Toyota Avalon
DVD PLAYER DIED ALL OF A SUDDEN. NO LIGHTS,NO POWER, NO SOUND. NOTHING. UNIT IS PLUGED IN AND WORKED FINE YESTERDAY.
Your probably got a blown fuse, You might want to unplug it pop off the cover and check the fuse. if its blown carefully take it out and bring it down to radio shack for a replacment.
hope that helps you out please to forget to rate.
Apr 05, 2010 | GoVideo D2730 DVD Player
Hi there, when i turn on my xbox 360 i can here the audio but cant get any picture. What can I do to fix this problem?
Try this as it worked for me.
First i took off my hard drive on the 360. Then i pluged it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) i only say this because i didn't use the HDTV setting to fix it. then i pluged it into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on i took 1 towel folded it long ways and wraped it around my 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. mine has been working for 3 days now with no problem i even have it hooked up using the HDTV cables in my living room.
Mar 21, 2010 | Video Game Consoles & Games
I need a transformer for a Milwakee job site radio.
The output voltage is 14v ac. It is printed on the circuit board that the wires go to
Mar 10, 2009 | GE Superadio III AM/FM
Neptune front load washer buttons wont work
I tried un pluging the machine for few hours and it will work for 3-4 load and then it will lock up again
Nov 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Waffle iron light is on but doesn't heat up
The same thing just happened to my waffle iron. It worked great for a few months and then no heat.
I took it apart and found the problem. Waring used a thermal fuse instead of a thermostat. The fuse is located between the waffle iron and the stainless cover. The issue I saw is that cooking oil (spray) gets in between the cover and griddle and soaks into the insulation covering the thermal fuse. The oil heats up inside there and shorts the fuse.
Replacing the fuse is easy and it is available at Radio Shack for $1.70 (part number 270-1321). It's a 442 degreeF.
The hard part about this job is diassembly and reassembly. I had to take the entire iron apart just to get to the fuse. It took about an hour to take apart and an hour to reassemble. Changing the fuse took 5 minutes.
Good Luck,
Jim
Nov 18, 2007 | Waring WMK300 Professional Belgian Waffle...
GE Superadio III AM/FM Logo
530 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
