Question about Symbol MC9090 Barcode Scanner
No Connection to 128WEP Encrypted AP with MC9090 but with MC9060
I want to connect the MC9090 to our 128Bit WEP Encrypted AccessPoints. When I connect our old model MC9060 there are no problems but the 9090 will not connect with same key and key index I used with the 9060. I can see the WLAN, but a connection is not possible.
I don't know what is the difference between both connection methods and what the AccessPoint maybe need or not like.
Any help or suggestions are very welocme
Thanks and regards...
Michael
Cant connect to wlan since 4 days
There may be a radio issue with the units.
Contact Lexicon Technologies for help - www.LexiconTech.com - 1.800.678.1744 - repair@LexiconTech.com
Aug 16, 2012 | Zebra Symbol Technologies MC909X-G Series...
How to get wi fi on ds lite
  1. Turn on the Nintendo DSi
  2. Click on the wrench icon to access "System Settings."
  3. Select "Internet" on the third page of System Settings.
  4. Select "Connection Settings" and tap the "None" bar in "Connection 1."
  5. You have the option of setting up a connection manually, or searching for available connections in the area. You may also access your Nintendo Wi-Fi USB connector, if you have one (the product has been discontinued). The easiest thing to do is select "Search for an Access Point."
  6. Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
  7. If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key.
  8. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify.
Jul 24, 2011 | Nintendo DS Lite Console
Internet
Turn on the Nintendo DSi then Click on the wrench icon to access "System Settings." Select "Internet" on the third page of System Settings. Select "Connection Settings" and tap the "None" bar in "Connection 1." You have the option of setting up a connection manually, or searching for available connections in the area. The easiest thing to do is select "Search for an Access Point." Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
Note Most Nintendo DS and DSi owners can get online by searching for an access point, but some might have to resort to manual setup.The Nintendo DSi can go online with a WPA connection, but actually playing DSi games online requires a WEP connection.
Jun 25, 2011 | Nintendo DSi Black Console
I can not get connection
Jun 25, 2011 | Nintendo DS Lite Console
The internal battery has failed on several of my MC9060 and 9090-g barcode scanners. How can I hard code the SSID and WEP key into the system so it never looses it?
When you have set up your wireless on your MC9090 you go to option from the radio Icon at the bottom right, and save and export the setting this is saved as a reg file. so everytime the MC is cold booted your settings are okay.
May 26, 2011 | Zebra Symbol Technologies MC909X-G Series...
How do you hook up the internet
Prerequisites:
  • A Nintendo DSi or Nintendo DSi XL
  • A broadband internet connection in your home, such as cable or ADSL
  • A wireless router / access point
  • You can also use a free public WiFi connection such as those found in McDonalds restaurants
Step by step instructions:
  1. Switch on your Nintendo DSi / DSi XL
  2. Click on the spanner icon to access - System Settings
  3. Select - Internet, on the 3rd page of - System Settings.
  4. Select - Connection Settings and tap the - None bar in - Connection 1
  5. You have 2 options here, you can setup a connecion manually or you can scan for available connections. The easiest option is to scan for an access point, select - Search for an Access Point
  6. The DSi / DSi XL will list the names of any access points that are in range. A yellow unlocked icon next to the connection name denotes an unlocked WEP connection. A locked yellow icon denotes an encrypted WEP connection that requires a WEP key or password to be entered
  7. If you are accessing an encrypted WEP connection, enter your WEP key now
  8. If the WEP key is correct, you should now be connected. Test your connection to verify this
Mar 06, 2011 | Nintendo DSi XL Burgundy
Can't connect ae1000 to a WEP encrypted bg access point
To connect to a WEP or any encrypted site, you will need to know and supply to your network connection:
  • the SSID (especially if the ID is not being broadcast as an additional safety feature).
  • the exact Encryption Key (normally entered in Hex format).
  • You need to exactly specify the security type (Open, Shared, WPA or WPA2) used for your wireless WEP connection as define on the access point wireless modem/router.
Hope it helps.
Sep 27, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
AP Wireless Network issue with MC9060
TRY TO UPGRADE THE AP FIRMWARE
Nov 09, 2009 | Symbol MC9060-G
Does the Symbol AP 3021 Access Point accept WPA encryption?
on the info i could find it only supports WEP.
but if your issue is to be more secure look up if it supports a sort of mac filter.
this will only keep everybody out of your router but your signal will only be WEP encrypted.
Feb 09, 2009 | Symbol Spectrum24 AP 3021 802.11b
Symbol MC9090 Barcode Scanner Logo
850 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
