Televison & Video Logo
Posted on Dec 02, 2008
THE OPTION TO ADJUST THE COLOR WILL NOT SHOW UP ON THE MAIN MENU
Anonymous
Level 1:
Problem Solver:
  • Contributor 31 Answers
  • Posted on Dec 02, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
31
Questions
Helped
4377
Points
53
Some of the tvs eliminate this option if the settings are on "auto color " or something similar depending on the brand; if that it doesn't fix it we will need more info.
2 Related Answers
Jaime Hernandez
  • 2351 Answers
  • Posted on Mar 31, 2008
SOURCE: rca tv problem
It is a common failure. It requires replacing a couple of ICs that we call STKs. The cost of repair is always $400 plus or minus unless you can do it by yourself (You should have some basic hand soldering skills in order to do the work because it requires some soldering AND some further testing for other components that may have failed in addition to the ICs).
Check for a part that looks like the one in this link but with a different part number that is mounted on a big heatsink.
Let me know if you require further assistance.
Anonymous
  • 31 Answers
SOURCE: Need to adjust convergence
this is a very nice tv very strong, but you have a problem on the convergence circuit or more likely on the power circuit for the convergence and this is the reason why the main processor it doesn't recognize this circuit. it need service not a mayor problem.
How to Solve error message Density High for Konica Magicolor 7540, Quality reduce after the message
it could be a number of things.you could try a full color calibration.otherwise , i believe you can adjust the individual colors also.try to press go and -value+ keys at the same time.see if the color adjust menu comes up.from there , you can print a color adjust page which will show many values and adjustment options.scroll around there to see different options.Or Still having Problem Then follow Us For
HP Support
How to adjust color for better picture
Hello there,
For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
Adjusting Your HDTV Settings
Using the On-screen Display (OSD)
The remote control or the control buttons on the side of the TV can control all the function settings. The
OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
settings, even if the TV is turned off.
The OSD consists of several menu options. The main menu options may vary depending on your
selected input source.
Note: Some of the main menu options may have additional submenus, for example, the TV Rating
submenu for Parental Controls.
The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
to the settings, even if the TV is turned off.
The HDTV Settings App consists of several menu options. The main menu options may vary depending
on your selected input source.
1. Press the VIA button.
2. Press ? or ? on the remote control to select the HDTV
Settings App, and then press OK. The Main Menu will be
shown on the screen.
3. Press ?, ?, ?, or ? on the remote control to select one of
the menu options:
? Input
? Wide
? CC
? Sleep Timer
? TV Settings
? PIP
? Network
? Bluetooth
? Help
4. Press OK to select the option or feature you want to adjust.
5. Once the menu option is displayed, press ? or ? on the
remote control to select one of the items to adjust.
6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
7. Press BACK once to return to the previous screen. To return to your program once adjustments
have been completed, you can do one of the following:
a. Press EXIT on the remote control.
b. Press the RED button on the remote control.
c. Highlight and select the RED X in any menu.
i hope this was helpful don't forget to Rate
I have Acer V203HV LCD Monitor.Even after installing the installation CD I cannot adjust the colour.The reason is when I click on Acer edisplay management the window highlights only option and extras...
Acer's economy V series models don't have any color mgmt built-in. Even the accompanying CD is not that useful.
The best way to adjust the color is - to use the video card's color management software. Based on your IGP / PCI-Express graphics card, check the settings in Catalyst or nVidia Control Panel.
I have a v203Hv model and I used the above technique, which helped me a lot to achieve the color, gamma balance.
I was cleaning the bottom of the screen and hit the color. Now it is blue and very hard to look at. I am at work, so I need this fixed
There should be a button that pulls up a menu to adjust color/contrast/ bright, etc. Press it and go through the menu options by either repeatedly pressing the menu button, or by using up-down-right left arrows. Adjust your colors using these options, or if available, try "auto" adjust.
I don't know this particular monitor, and am no "expert", but these options should be available on virtually any LCD monitor. A final option, if adjusting these does not help, look at all the menu - settings. If you see "recall" or "restore" or "default" anywhere, try selecting that option.
Good luck
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
We have an Emerson 20inch tv that suddenly lost it's color.
Do a reset to this TV and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
2helpful
52 inch rca shows picture in 3 colors will not focus
is thr convergence adjustment option still listed in the on screen menu? Let me know and I will try to assist you.
Componet 1 and WII
First of all, make sure that you have the colors of the component cable matched correctly. You can switch the Pr and Pb cable and still get a picture although in the wrong color.
Secondly, go to the TV menu... the menu should still be in color. If it is in B/W then you might have a hardware issue. Try adjusting the custom color setting so that you get a blue picture or red picture. There is an option for adjusting the color called "blue mute" it should give you a perfectly blue picture. If you still don't get any color than it is a hardware issue. It could be the Main Board or the Control Board.
It was the Main Board in my case.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
