Question about Philips Magnavox TS3260C 32" TV
Hortizontal line when i turn the tv on, there is olny a balck screen with a white horizontal line in the middle of it. yesterday, when this happend i hit the tv and it worked. now its not responding to that anymore. is there anyhitng i cna do to fix this myself? if so how? also i spilled some water on the circut breaker its attched to this morning by acident. ccouild that have anythign to do with this? everything else on the curcit breaker is working perfectly fine.
From your description of the problem, there seems to be a Cold solder in the Vertical Oscillator or Deflection Coil circuits. If you know Solid State electronics, and are good with a soldering Iron, sure u can do this yourself. U gotta trace the Vertical section components and locate the cold solder. In most cases it will be a loose connector from the Deflection coil to the main PCB.Also check for the soldering of the Vertical output IC.
Posted on Jan 29, 2007
We purchased a Sony KDL-46W3000 LVD TV in May 2008. Just recently the left side of the screen has started having problems with hortizontal grey bars and white lines and the screen jumping around when the...
Hi I have an old school solution for your problem with your tv. Hit it!!!!! When you turn on your tv, go to it and lightly tap on the middle of the left frame. You should see it affect your screen. Do it until your screen is perfect. Hope it works.
Jun 22, 2011 | Sony BRAVIA KDL-46W3000 Television
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Black screen with a horizontal white line across the middle.
You would need to replace the flyback on this and your looking aroung $65 parts and $85 labor to shore this problem up. We can recommend you a repair shop or you can purchase a new TV its all up to you
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 02, 2009 | Sanyo DS24205 24" TV
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Philips Magnavox TS3260C 32" TV Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
