Question about Casio Exilim EX-S600 Digital Camera
My casio EX - Z550 lens will not open please help
Casio EX-Z550 lens on digital camera will not open. Green light flashes. The lens opens a tiny bit then goes back in. On screen it says lens error.
3 Suggested Answers
SOURCE:
mcomijohns
  • 477 Answers
SOURCE: Casio Exilim EX-Z70 lens error
yes I can help you lens zoom motor is out or the gears are stripped. goto www.digitalcamrepair.com for more help.
Posted on Jun 12, 2008
  • 11967 Answers
SOURCE: my casio exilim EX-Z550 reports a "lens error"
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 02, 2011
I need an instruction manual in English for the Casio Exilim EX-Z550
You can download and print the instruction manual in English for the Casio Exilim EX-Z550 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Oct 29, 2010 | Casio EXZ550 Digital Camera
I get Lens error 2 msg as soon as I open the lens cover, then it vanishes, how to fix this problem in Casio Exilim-V8
HI
I BUY A DIGITAL CAMERA EX-V8 CASIO
BUT WHEN I WOULD TAKE A PICTURE , IT WAS DAMAGED AND ((LENS ERROR 2)) WAS APPEARED BUT I CAN TAKE PICS AND MOVIE
WOULD U PLEASE GUIDE ME???
PLEASE SEND YOUR SOLUTION TO ALIREZA.S@SNSIRAN.COM
THX
Feb 28, 2009 | Casio EX-V8 Digital Camera
Casio EX-S500
That is what Casio calls a "lens error". It needs to be sent into repairs.
Jul 29, 2008 | Casio Exilim EX-S600 Digital Camera
Jun 12, 2008 | Casio Exilim EX-Z750 Digital Camera
Lens do not open
More than likely lens is off track. send into casio to have it fixed.
Oct 19, 2007 | Casio Exilim EX-S600 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
101 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
