I set my router up as a network and all I want it to do is run a laptop. How do I get it to do just that?
    Scholar:
  • 57 Answers
Did you have it working with another computer before? It would normally use an ethernet cable between the router and laptop.
Your laptop needs an ethernet connector (or maybe a USB port if your router supports a USB connector). Sometimes the ethernet port is built into the laptop. It looks like a phone jack (you may have a couple of modem jacks on your laptop, which is not what you want). It's bigger and has 6 wires instead of 4. Another way to connect an ethernet cable to your laptop is a PCMCIA card. They plug into a thin, wide port on the side of your laptop. It also would have the 6-wire jack built into it. Router setup is another issue if you need help with that.
Posted on Dec 02, 2008
Wireless
run a hard wire from your laptop to your router.
Goto internet  on your computer, at the  http: type in 168.192.1.1  click enter
welcome to your wireless interface
                           Network Security Settings:
router username:                   admin
router password:                   brown243bag
network name (SSID):               Digital1Denizen
network security type:             Better compatibility with legacy devices (WEP-128)
network security key:              F79397B4822B17D6EB4E169E8E
exit
Nov 27, 2010 | Computers & Internet
Laptop can't connect to DSL-G604T
You need to configure your router and use WPA encryption so that all accessing device can connect to it.
The obvious reason why the dell laptop can't connect is because of the WPA encryption set. It is different compared with what your router is actually broadcasting: WPA2.
So you can choose one of the 2 things to alter. Change your router's WPA2 encryption to WPA or change your Dell's setup to WPA2.
Mar 05, 2010 | D-Link DSL-G604T Wireless Router
My new laptop with Windows7 OS cannot connect either wireless or direct cable to DLInk DI624. I have tried turning off my firewall but still same problem persist. The router is working fine with my old pc...
Adding a wired computer or device to the network.
If you router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you are adding a desktop or any other device to the router which will always be connected to the router with the Ethernet cable, then in this case you don't need to do anything.
You can just connect the Ethernet cable between the router and the computer and it should work.
If you are not able to go online even when it is connected properly then check IP address of the computer.
Adding a wireless computer or device to the network.
If you want to add a new wireless device ( laptop or any other wireless device) to the network, then you should know all the wireless settings of the router. What wireless settings do you need to know ?
You should know the wireless network name ( SSID ), wireless channel and the wireless security password
( network key ). Once you get all the wireless settings of the router , you will need to connect to the wireless network on the computer. when you try to connect to the network , you will see your wireless network in the list. You just need to select your network and connect to it. If it is secured then you will need to enter the network key and you will be able to go online.
To check the wireless settings of the router , you will need to access the router set up page. On the set up page you will find all the wireless settings of the router.
click Here for step by step instructions
Dec 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
My router problem was not resolved and I can't reach you guys 4 assistance!
... and your problem is _________________________ ???
With an Ethernet cable, connect the "wired" port on your desktop/laptop to one of the "wired" ports on the router.
Access the router's built-in web-server, and "reset" the router to "factory-settings".
Then, run the "Wired Networking Setup Wizard".
Then, run the "Wireless Networking Setup Wizard",
to configure your wireless network, for up to 250 wireless devices (iPod Touch, laptops, et cetera).
Dec 28, 2009 | Toshiba WRC-1000 Router (PA3227C1ETC)
I have a belkin router set up in my home and I just purchased a 2nd laptop but I am unsure how to add this new laptp to the connector
Click Here for step by step instructions
Dec 27, 2009 | Belkin (F5D7231-4) Wireless Router
I misplaced my cd to connect my other laptop to the wireless router, WRT54G, and I'm trying to get it through your site
If your router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
Click Here for more info
Dec 19, 2009 | Linksys Wireless-N WRT150N Router
Cannot connect my laptop to internet through router wrt54g v8
Make sure you have ipx and spx protocol installed, and a home network setup through windows. Also if the first try don't work make sure you firewall setting is not blocking your router.
Dec 03, 2009 | Linksys Wireless-G WRT54G Router
Setting up and configuring networks
The main problem on your setup is your router. This BEFSR41 doesn't have wi-fi or wireless capability. You can only go online on your laptop if you connect it hardwired to the router just like your desktop. You must purchase a wireless router if you want your laptop to work wirelessly
May 09, 2009 | Linksys BEFSR41 Cable/DSL Router with 4...
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
WLAN connection
make sure that your wireless network card works.go to the settings of your router and set: wireless network mode:802.11b(or what your car supports) wireless network name:name Wireless SSID Broadcast:enabled Security Mode:wep wep key:write something create a new connection to your laptop with the above settings
Oct 04, 2007 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
