Question about Whirlpool GY396 Electric Kitchen Range
Whirpool electric oven replacing bake element
I am working on a Whirlpool electric oven with a hidden bake element I need to replace it but have no Ideal how to get in to it Model number GR563LXSB1
  • Jerry Green Dec 02, 2008
    This is a free standing range , I will try to see if can get into it tomorrow. Thanks
In addition to what aborcass stated, I just had to fix the same problem. Remeber to turn off the power before you do this. On my stove the element acess is behind the side panel (right side when facing the stove). You remove two screws on the back and one underneath at the bottom, (you need to pull out the drawer). Once screws are out, slide the side panel forward gently about an inch and it should just drop off.
You should see the wires for the element level with the bottom of the stove. The wires will guide you to the element. And you should see that the element is screwed in with two screws to the stove. This is the tricky bit, to remove the element follow the metal piece holding the element to the right until you see a third screw. Remove this screw and the whole thing will come out. Take off the wires, replace the element on the metal strip, slide the element and metal strip back into the stove (take care to ensure the left side of the metal strip slides into the proper position under the metal clasp. Re-attach the screw, plug the wires onto the element and turn the power back on. You should have heat.
Good luck.
Posted on Apr 05, 2009
    President:
  • Whirlpool Master
  • 2,651 Answers
You will need to remove form the wall and access from behind, after removing hte back panel you see the 2 wires leading to the elemnt in the bottom right corner of unit, a few screws will remov ehte element form hte uit nad the new one will slide right in, if by some reason its not behind that panel 2 screws will remove the side panel and gain access form there
Posted on Dec 02, 2008
Gr673lxss 1 how to find hidden bake element
Kyle,
Usually what they mean by "hidden" element means that the bake element sits in a recessed part of the oven cavity. You only have one bake element and one broil element in the oven. Hope this helps.
Mar 13, 2015 | Whirlpool Electric Range
How to replace the lower, hidden bake element in the lower oven of an Electrolux Icon oven
You need a 1/4 or 1/16 mm. to take it out, they always have a simgle plug.
Nov 13, 2013 | Electrolux Ovens
I need a manual for Whirlpool Range Mod. # GLP85200. Something that shows how to get to the Hidden bake element.
Welcome to FixYa.
The Whirpool Range Manual is Generic, you can download it >>HERE (in PDF format).
To remove the bake element, remove the screw that holds it from the inside then pull it outwards.
You need to put a little force.
Thank you for using FixYa.
Jas
Sep 01, 2011 | Ovens
How to get access to bottom element (not visible modle) to replace ir?
That model is not shown as hidden bake but the bottom would have have to lift up to uncover the element .
Nov 19, 2010 | Whirlpool RBS245PDS Electric Single Oven
GE double convection oven model GBD307 has stopped working.
my bake element stop working it is hidden and can't find out where i need to replace it,whirpool can you help
Dec 19, 2009 | GE Ovens
I need to replace my bake element on the bottom of the oven. I have removed the plate but do not know how the wires disconnect
they are just a push-on spade terminal,pull them off replace the element and carefully push-on the terminals to the element
Nov 18, 2009 | Whirlpool GSC278PJS Oven
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirpool electric range - RF196LXMQ - Will not reach 350 degrees
When using Broil, it is normal for only the top element to work and it depends on the oven whether both should be on or not for baking but typically, baking does not use the upper element otherwise it could burn baked goods.
If setting the temperature higher than 350 does not cause the lower element to turn on, then it's likely that the thermostat has failed and can no longer respond to the temperature set.
The fact that both elements work under some conditions means that both of the heater elements are working at least some of the time. Because of the primitive nature of the elements, it isn't possible for them to just become 'weak' but they can interrupt themselves if there is a break in the resistance element but you could only separate the two possibilities by measuring the hot coil and that would be difficult unless you can pull the range out and access the AC feed lines that go to the element. Obviously, the power would have to be disconnected and the measurement done quickly so the element didn't have time to cool and regain continuity.
Nov 27, 2008 | Whirlpool RF364 Electric Kitchen Range
Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Nov 03, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
BOTTOM COIL DOES NOT HEAT UP
my bottom element in my Whirpool range needs to be replaced. It is hidden. How do you replace it?
Jul 20, 2008 | Whirlpool RF364 Electric Kitchen Range
Whirlpool GY396 Electric Kitchen Range Logo
1,949 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
