Question about Sony Playstation 3 (PS3) Console
How do I find a lost account on ps3 online? and where do i find the ip address to enter
  • 261 Answers
This is the site http://www.ip-details.com/ which helps to find the ip address.It's useful for you.
Posted on Sep 22, 2009
  • 3 Answers
Posted on Dec 02, 2008
3 Suggested Answers
  • 3 Answers
SOURCE: ip address
get the ip from your wireless router
Posted on Apr 01, 2008
GetRich09
  • 10 Answers
SOURCE: My ps3 cannot find my ip address.
Handlung ist das echte Maß der Intelligenz.
Posted on Mar 27, 2009
My PS3 can't find the IP address for my wireless router and I don't know how to enter it
possible cause is that ps3 uses an ip address leased from the wi fi router via its DHCP Server in Router. If PS3 was off for a while another computer on Wi FI network may have been assigned the IP address that the PS3 thinks it has.
Try page 29 of
http://au.playstation.com/media/2Pv7AFEC/CECH-2102B_2103B-3.20_UKANZ[EN]_vf1.pdf
on page 31 change the ip address setting to manual
set ip to 192.168.0.254 subnet mask 255.255.255.0
Now exit setup
Then go back into Setup
Change IP address setting to Auto
Why
This will renew the ip address from the DHCP server to the ps3 hopefully allocating you a fresh IP address lease .
Feb 19, 2016 | Sony Playstation 3 (PS3) Console
I can play any game online fine, but when it comes to fifa i send my friend an invite he accepts then nothing happens it just comes up this game session is no longer active, or when i do get a game it says...
You need to either give your PS3 a static IP address and then put that IP in DMZ in your router, or you need to open up the ports it tells you in the Fifa 09 manual.
To put your PS3 into a DMZ (To be done on the PS3 Console)
Firstly, you will need to assign your PS3 a static internal Ip address. This means that everytime your PS3 connects or "talks" to your router, the router will assign it a different internal IP address. These IP addresses typically run in series. So for example, if your PS3 is the second device communicating with your router, then it will be assigned an ip address of 192.168.1.3. However, if you choose to use your PS3 without the computer being on, the assigned IP address your PS3 has will be 192.168.1.2. As this is different, and obviously will change, it would be stupid setting a DMZ up on one of the above Ip addresses, unless your PS3 was the only device that would ALWAYS connect using that specific IP.
To make sure that your PS3 is always assigned the same internal IP address by your router, you will need to go to the "Settings > Network Settings > Internet Connection Settings" option on the PS3 Cross bar menus.
You will be presented with an option which primarily asks whether you are using a Wired or Wireless connection. Obviously, you will choose the option which refers to you. If choosing the Wireless option you will need to input the security details in use on your router *If you are not currently using wireless security, i strongly reccommend you do so ASAP*
Both selections should show a page called "Address Settings". Here you will need to select "Custom". Another page will then display entitled "IP Address Setting". The option "Manual" will need to be selected.
This will display a page where customisable IP Addresses are available to be selected.
IP Address - This will need to have the Static IP address in it. Personally, i use 192.168.1.100. I use this because it is extremely unlikely my Router will ever automatically assign this IP Address to a device, as i will never have 99 other devices connected to the same system.
Subnet Mask - Is always set to 255.255.255.0
Default Router - Is the internal IP Address of your router.
To get the exact ip of your router you should go to
Start
Run
cmd [Hit Enter]
Type in ipconfig and hit enter, this should come up with all the ip addresses to do with your computer and the network. The address you will need to enter in this option is listed as "Default Gateway".
Primary DNS - Same IP Address as "Default Router"
Secondary DNS - Same IP Address as "Default Router"
After entering all of these IP Addresses, you will now click "Enter" or hit the "right" button on the D-Pad. This will take you to a screen which says "MTU" at the top. My setup has this as Automatic, solely because i haven't a clue what MTU actually means or does.This won't affect your ability to set up a DMZ.
The next steps are very simple. You do not want to use a proxy server unless you connect to the internet using one, however i can be of no help there, and you should enable UPnP if your router supports it.
To put your PS3 into a DMZ (To be done on the PC)
Now head over to your PC, and load up your internet browser. In the Address Bar, type the IP Address of your router (the one you found using the Command Prompt earlier)
This will take you to your Router Configuration Page.
Every router interface differs from an other, and depending on what router firmware update you last installed, router interfaces can differ, even on the same model routers. This means that you will need to search the router config page yourself. You are looking for any mention of "DMZ" or "DMZ Host"
When you have found this, it will ask you generally to input the IP Address of your DMZ Host, which is just the static IP address you assigned to your PS3 earlier, my example was 192.168.1.100, so we'll stick with that. Then click "apply" or similar.
You should then turn off everything running on your home network. PS3, PC, Router etc. This is solely to make sure that the changes are applied as soon as possible.
This should fix all of the problems as listed earlier in this guide, and probably some other issues
May 19, 2009 | Sony Playstation 3 (PS3) Console
Help me
you need to set up an account on ya PS3 then set up an e-mail and send to registered e-mail address and clik on the link in ya e-mail inbox to activate your PS3 account (think it's password protected too ) then happy playing if ya short on friend's add devilutd01 on PS3 .
Apr 16, 2009 | Ubi Soft Entertainment Tom Clancy's...
Ps3 sharing an ip address
it's something with your router. try assinging static ip addresses. that'll fix it. or contact your router manufactere and ask about DHCP and figure out that way why your router is assigning everthing the same ip address
Mar 29, 2009 | Sony Playstation 3 (PS3) Console
Mar 27, 2009 | Sony PlayStation 3 40GB System
Dns error when connecting how do I fix this
Unstable connection. if you have wireless connection that could be a problem depending on your environment. Try turning off your firewall too by calling your internet server(Comcast,DSL,etc.)
Jul 31, 2008 | Sony Playstation 3 (PS3) Console
HELP
If the game you'er playing on PSP requires opening a certain port then access the setup page of the router by going to 192.168.2.1. Go to and place the port number of the game and enter the IP address of your PS3. You may also set the PS3 to DMZ if you know the IP address of your PS3.
Or call the toll-free Supportrix Tech Support at 1-877-787-8749 and give "support call" as promo code for one free technical support call.
May 03, 2008 | Belkin (F5D7230-4) Router (587009)
80710092
dns error, try entering the following in your ps3. Settings - Network Settings - internet connection settings - custom - wired or wireless depending on your internet - manual settings - IP address manual - enter your ip address and your router address and change your dns primary 208.67.222.222 and secondry 208.67.220.220 this will enable you to go online as for the error code 80710092 i have no idea, im experiancing the same problem. its so frustrating. as soon as i find the answer i will let you know.
Apr 14, 2008 | Sony Playstation 3 (PS3) Console
Ip address
Apr 01, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
121 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
