Question about Epson Stylus Photo R340 InkJet Printer
Epson stylus photo r340 paper feeder
I have an epson r340 printer,i`ve only had it for just over a month and it`s stopped feeding paper all together! can anyone tell me what the problem could be?.... It was working fine all day yesterday until i wanted to do another print then it just stopped all together. all epson what to do is replace a brand new printer which i paid quite a bit of cash for, for a quality assuered printer and beleive me they can also give problems too. So anyway if anyone has any suggestions, i would be happy for the information given ... Many thanks
  • Dave Haynie Dec 02, 2007
    I have owned several Epson printers, and not a one could feed paper properly to save it's life. I literally have to manually feed every sheet or CD/DVD into my R300. Even the P2000 I use for high end printing has issues, and that was an $800 printer when new. This borders on false advertising, claiming to have a sheet feeder on these things. Never found any sort of solution.
    On the other hand, I have an HP 970Cx here, used for business printing, that's never jammed or misfed a sheet in it's life. It even does duplex printing properly, and it's feeding uphill -- Epson has gravity on their side, and still can't get it right.
    Now, I have no trouble with the output -- Epsons produce BEAUTIFUL prints, if you can get the frickin' things to accept paper. If they made a model that actually fed paper properly, or if HP made a good photo printer with CD/DVD support, I'd buy either in a heartbeat. If I didn't need CD/DVD printing, I'd never look at Epson again, despite the print quality.
    Problem Solver:
  • 16 Answers
The friction feed roll might be dirty from paper lint, ink glazed or it might have something stuck in it ( a piece of paper from a jam etc.)
Posted on Nov 12, 2007
I have now broken my third Epson printer (R340 this time) following a paper jam. If you can't get at the paper to pull it through in the direction of normal flow, you have to pull it back from the paper feed tray. This can easily break something inside the printer. I agree with the note from HazyDave. Epson printers print very well indeed. Their photo quality is first class.Their paper feed is poor & unreliable; access to the interior is very difficult so that jams may be very difficult to rectify.
Posted on Jan 19, 2008
Epson Photo R340 will not load paper
Application of WD-40 to the feed roller is preventing it from functioning correctly.
Feb 18, 2018 | Epson Stylus® Photo R340 InkJet Printer
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
I checked the steps on your Epson R340 Paper Feed problem. Both of our R340s are about a year and a half old and they are both having the same problem. There is nothing wrong with the paper . . . it...
hello, eventually the feed roller will need to be cleaned, it collects paper dust and dust and inks, so becomes smooth, and unable to grab paper properly, cleaning with alcohol, yes it does clean but dries rubber, WD-40, is waht i use, but i allow it to be absorbed into roller, then wipe off the excess, then try feeding paper.
Oct 14, 2010 | Epson Stylus Photo R340 InkJet Printer
Printer won't print with Hahnemuhle 300gsm papers.
Brand new printer feed up to 350 gsm paper. Rubber paper paper pick up deterioration. Replace paper feeder. Or find similar solution (repairing paper feeder) on aicaxz's for resolving this.
Feb 02, 2010 | Epson Stylus Photo R220 InkJet Printer
Epson R340 does not feed paper or feeds it crooked so print is not square. Out of paper error when paper does not feed.
two things I would do, first carefully flip the printer upside down, (anything that looks like it can flap open, tape it well), and jiggle it slightly and see if anything falls out.
second, i would clean the pickup roller with an alcoholic pad or swab, if its not easily accessible, you will probably need to take the upper an middle casing off, which I dont recommend.
thanks adi
Jan 02, 2010 | Epson Stylus Photo R340 InkJet Printer
EPSON 1280 SILVER INK JET PRINTER, Stopped printing on glossy
Problem with paper feeder. Replace paper feeder or replace just pick up rubber at paper feeder mechanics. You can add thickness of rubber by adding black double tape (flexible) (about 1mm).
Jun 15, 2009 | Epson Stylus 2200 InkJet Photo Printer
I am trying to print a 4X6 postcard from my epson stylus photo r340, and it just won't take that paper. It prints 8 1/2" X 11" just fine. Any ideas?
Change the printer settings: Right Click the Printer, click Printing Preferences, on Paper Size click 4R or 6 x 4 photo..SOLVE
Feb 23, 2009 | Epson Stylus Photo R340 InkJet Printer
Paper will not load into my Epson PHOTO R340 printer.
May be the problem is at paper sensor, that dirty. The sensor is at bottom of head casing. When paper feeding, the sensor not get the light back, so the printer "think" that no paper. Try to clean paper sensor.
Jan 12, 2009 | Epson Stylus® Photo R340 InkJet Printer
I need the software & drivers please 4 epson styuls photo R220 some one send it to wickedwelchtattoos@att.net thank you.
Sep 22, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson R340 not loading ultra premium glossy photo paper correctly
I have several Epson printers and it would seem this is common, I am on my fourth replacement printer, Epson keeps shipping them.
Mar 08, 2008 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus Photo R340 InkJet Printer Logo
841 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
