Question about Canon CLC 1150 Color Copier
Canon CLC1000 E350 code error
Hello. You answered the question about this code and suggested that the card reader is faulty and /or the connection between pcb and reader is faulty. Your statement ' canon does not make readers anymore' is clear but you did not suggest any way forward to keep using this copier. Does this mean the copier is no longer usable and we need to throw it away or we need to disable a function somehwere to move on? please help by elaborating how we can continue from this challenge.
  • 67 Answers
You will be unable to make copies but should be able to continue to print from your computer
Posted on Dec 06, 2008
Ir 3300 copier error code e000732-0001
Canon iR3300 Error Codes Code: E732-0001
Code
E732-0001
Description
A fault is detected by the main controller PCB in the communication between reader controller PCB and the main controller PCB
Causes
The connector has poor connection. The reader controller PCB is faulty.
Remedy
1. Connector, Reader controller PCB Is the connection between the connector J1014 on the main controller PCB and the connector J409 on the reader controller PCB normal? NO: Correct the connection. YES: Replace the reader controller PCB.
Below is the site this came from which lists all the error codes in case another occurs after you resolve this one
Canon iR3300 Error Codes List page 1 from 12
Aug 27, 2016 | Canon Ir 3300 Black & White Copier
Error code e000225-0001 for canon I r 3035 what I do pls. help me
The light intensity of the CIS is faulty.
During DF stream reading, the sheet-to-sheet light intensity is faulty.
Disconnect and then connect the flexible cable. Replace the following as necessary: flexible cable, CIS, reader controller PCB. Canon iR3035 Error Codes List page 3 from 16
Aug 15, 2016 | Canon iR3035 Copier
Error e350 canon ir 6000
pls help canon ir6000 error E350-3000 solved the problems
Jun 27, 2012 | Canon Service Manual For Ir 6000
E350-3000 or e350-0002 this error code ,how to solve the error
under ir8500 I can't find the error 350, so exact solution It can't be recommended...
But generally error of 300 type are related to problems with dc controller pcb and only solution is to reconnect the connectors or replace dc controller ( main pcb ).
Sep 15, 2011 | Canon imageRUNNER 8500 Copier
Hi i am getting E061 0127 on canon clc1000, what is this error means? thanks
Basicly the code means that one of the 4 drums is not charging correctly. You may have to change the post charge wires and or one of the drums
Apr 02, 2010 | Canon CLC 1000 Color Copier
Help me.....faster....
Errors commencing with E3---- means that something to do with the reader unit,,,, apart that error mentioned does not exist. If youhave plenty of parts that you can try out I will try to replace the reader board....
Dec 15, 2008 | Canon imageRUNNER 5000 Copier
Error code E350-0000 on canon clc 1000
the connection between eco-id pcb and reader controller is faulty, canon do not make reader controller anymore
Sep 03, 2008 | Canon CLC 1000 Color Copier
E 247 & E350
1---THE ECO-ID PCB IS NOT MOUNTED OR THE CONNECTION TO THE READER CONTROLL IS FAULTY,
May 03, 2008 | Canon imageRUNNER 5000 Copier
HOW TO CLEAR ERROR E350-0000
Did you recently clear RCON and tried to due a CCD adjust? The problem could be the that the left side glass retainer changed or mared or has a doc feeder been added or removed. There is a bar code on the under side of it. The part number for the 1000/3100 is FF5-4662-020, the 2400 FF5-8802-000
Jan 25, 2008 | Canon CLC 1000 Color Copier
Clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
May 18, 2007 | Canon CLC 1150 Color Copier
Canon CLC 1150 Color Copier Logo
113 people viewed this question
old marine
old marine
