Question about Kenmore 24032\24036 Top Load Washer
I have a kenmore washer,top load about 14 yrs. old. agitator does not turn, but when i put pressure on it, like hold my hand on top of it, it turns. help
    President:
  • 2,992 Answers
Most likely you need to replace something called the agitator dogs. There's a website that has pictures of the parts and more troubleshooting tips, so you might want to check them out.
http://repair2000.com/agitate.htm
Posted on Dec 05, 2008
GE Washer will not agitate but it will spin
Put old coupler back on transmission shaft. Can you now turn coupler? You should not be able to. If you can, grooves in coupler are stripped out. Replace coupler. Part # WH49X10042
Sep 13, 2017 | GE WDSR2080D Top Load Washer
I have a Lady Kenmore Ultra Fabric Care Heavy Duty 90 series top load washer that is about 20-25 years old and works very well. I think that an object has slid under the big thing in the middle of the...
if it is like the other you have to remove the top cover of the agitator cap with a small flat head screwdriver, then using a 7/16" socket and ratchet with an extension remove the bolt(right hand thread) and pull up the agitator.
good luck to you.
Feb 08, 2011 | Kenmore Washing Machines
WASHER WILL NOT AGITATE OR SPIN WILL FILL AND DRAIN KENMORE 800 TOP LOADER APROX 13 YRS OLD
sounds like your motor coupler bad if its making a ratchety kind of noise
Jan 15, 2010 | Kenmore 23822 Top Load Washer
How do you remove the ajitator from a Beaumark millennium washer
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Top load, two piece agitator(s) use what are called "Agitator Dogs" which allow the top piece of the two piece agitator to turn in one direction only. This keeps the clothes down in the tub instead of bunching at the top of the drum.
If the Agitator Dogs (small plastic pieces) are worn, the top of the agitator won't turn.
Following is a description of how to access and replace them.
They are relatively inexpensive. See the Sears site for part numbers and costs.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=dd841e41a5cd8a4c571fdac319ed00b0
Nov 25, 2009 | Washing Machines
Agitator not agitating whirlpool quiet care 11 about 9 yrs old
Please see the Whirlpool installation and maintenance PDF on their Top Load, Direct Drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If this is the type of washer that you have, I'd pull the cabinet and check the Motor Coupler.
Following is a description of how to do it.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
If it isn't the coupler, and you want to go further, it is possible that the "Agitate Gear" in the transmission is damaged.
Here is a description of how to "pull" the transmission on top load washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Although getting into the transmission is somewhat messy (it holds about 14 oz. of oil) it can be done, and replacing the gear isn't too difficult.
Oct 01, 2009 | Washing Machines
My agitator turns sopradically.
pop the cap off it,you will see 4 little gears called dogs,theses have to be replaced they work the agitator-mike
Jul 22, 2009 | Kenmore 24032\24036 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 18, 2009 | Kenmore 24032\24036 Top Load Washer
Top half of agatator don't turn
Remove the agitator. Place it on the floor. Put your feet on the base and yank the top portion off. Replace these:
124bfd8.jpgPart number 80040 agit dogs(4)
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
