Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Bosh dishwater does not fills with water: seems it shuts down!
Hi, I bougt an bosch dishwasher an oldy to keep me at ease until i get in my new house where new equipment will be installed. This oldy, sometimes it stops filling with water and the program halts. When i tilt it an couple degrees, water comes spilling from unterneath. That must not be normal. I Reckon. But after that it restarts , fills with water and everything works fine until the next day. My quess its leaking somewhere and a sensor shuts it down. But how do I open the pan to inspect it? Suggestions? Diagrams , photot;s how to remove the pan? Thakns Steve Soer Roes
  • 909 Answers
99%of the time it is lesking at the pump motor. needs to be done by a technician.a fair amount of stripping
Posted on Aug 15, 2007
    President:
  • 1,462 Answers
You have a leak probably from circ pump. there is a float in the base which when lifted by water, shuts everything down and turns on the drain pump
Posted on Mar 22, 2007
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
I have A bosh SKT 2052 Will not fill up to start the cycle
see the following causes:
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher) see diagram
2) faulty float switch, test for open or faulty.
see the diagram attached.
God bless you
Jul 11, 2012 | Bosch 22 in. SKT5102 Free-Standing...
What is E24 on my Bosch super silence dishwasher?
Check the air gap! It may be clogged.
There is a great video explaining how to do t linked below.
My air gap was clogged, and after cleaning it the error 24 was gone...
The Diswasher Air gap how to clean it and why it important
Jan 02, 2011 | Dishwashers
Water keeps filling even if dishwater is off or if the door is open, the only way to stop it is from turning tap valve off below the sink.
Your dishwasher water fill valve is defective. Remove power from the DW. Remove the bottom toe kick panel. The water valve has the incoming water line connected to it.Remove the wires from the valve. If the water stops entering you have a bad timer. If it makes no difference you have a bad valve. The valve is a replaceable part. The timer is a replaceable part.
Dec 16, 2009 | KitchenAid KUDS01DJ - Multiple Color...
Dishwater not filling with water when switched on.
Hi nitwit2,
I'm Harvey the Master Plumber.
Your problem is: Dishwater not filling with water when switched on.
Electric on? Good. 9 times out of 10 it's a bad solenoid valve. It's under the d/w behind the kickplate on the left. I don't recomend this repair for the average homeowner. You might look in the Repair Directory for a repairman. If you're up to it, I find removing the d/w from the cabinet facilitates installation.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | Bosch Dishwashers
Diswasher wont fill
Faulty fill valve?
Timeing out with insufficient flow of water?
Hot water to hot and locking up valve?
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher down
check supply to the d/w. it thats ok some have a shut of valve if water leaks into the btm panel or the inlet valve is faulty
Dec 28, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh dish waher
Does it make the same noise when it's just filling or just when the motor starts? Usually just filling the dishwasher opens a valve and doesn't run the pump. If it makes noise during filling the valve may be getting hot and shorting, or may have a loose connection, or air may be in the water supply line causing the valve to bounce. If it takes a long time to fill the filter may be clogged.
Nov 30, 2007 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
233 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
