Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Hello I am having trouble with my picture on my TV. I can't see the top of people's head. Can you help.
  • 2 more comments
  • Anonymous Dec 02, 2008
    I have the same problem
  • vmsdancer2 Jan 11, 2009
    I can not see top of heads
  • lilsin22 Jan 12, 2009
    cant see the top of peoples heads and now there are lines through the screen green red blue and its curved on the bottom.
  • tumunga May 11, 2010
    Do you have the correct resolution set on the tv? Is the zoom function on?
Go left and right (arrow buttons) on your tv remote to go from 4:3 format, widescreen, 14:9, etc. If you have non-hdtv (full screen), its best to leave it on cinerama or 4:3/
Posted on Jan 13, 2009
Hello, I have a Craig CLC503 TV as well and having trouble getting my cable channels and clear pictures. Any help with this would be appreciated.
First, change the input to some other you are sure works well and see. Then if the problem persists, this might need attention by a qualified service technician.
Jul 24, 2012 | Craig CLC501 15 in. TV
Hello...the image of the TV is so big its cutting people's heads on half.. there is something wrong with the picture it looks big and the higher part cuts heads or foreheads...
Hello there... You access its zoom. Zoom it out (until you get the desired or normal size) or simply turn off its zoom. Hope this helps... Ai-ai
Jan 09, 2010 | RCA Televison & Video
TV picture compressed top and bottom, then turned itself off
hi i think you have trouble on the power supply section.
Aug 24, 2009 | Televison & Video
Tv has three rainbows on top of screen and picture looks funny
hello it sound like you've got convergance trouble have you tryed convergance setting if so and this hasn't worked the you will have to change the convergance chips get an engineer to give you quote it's a big job trust me i've done a couple myself all the best
shaun
May 01, 2009 | RCA P52926 52" Rear Projection Television
Tv only has top right corner showing picture
Hello the picture was good 2 days ago.I took a picture of the plasma ..could please help me with some ideas...thank you..
Mar 24, 2009 | Akai PDP42Z5TA 42 in. Plasma Television
Image larger than screen on toshiba cx21419
You have Vertcle problem .Which causes pitcure hieght to be streached. Should call TV repair shop.
Nov 04, 2008 | Toshiba Televison & Video
Green Spot in picture
Did you try unplugging TV from outlet for an hour, sounds like degaussing trouble, was there a speaker or magnet placed close to the TV?
Jul 06, 2008 | Philips 20DV6942 20 in. TV/DVD Combo
Picture on Panasonic tv intermittently becomes striated and bottom half of picture shows on top half of screen
Hello! What you're describing sounds like a vertical deflection problem if it also occurs when you're watching a TV program. This type of trouble is a component failing in the vertical circuit of your set. A loose solder connection could cause this. On the other hand, if it just happens when you run the VCR, your problem could be somewhere in the tape drive mechanism or possibly a bad tape. Things like slipping clutches,bad belts sticking guide rollers are a few things that will cause this in a VCR. You need to have a tech check it for you. Hope this gives you some help. Stargazer
Feb 03, 2007 | Panasonic CT-34WX54 34" TV
Help problem with picture
This sounds like theres a capacitor somewhere in the vertical sweep circuit. You can replace the capacitor if you have a soldering iron and some electronic experience on trouble shooting tv sets. It is most likely from what you described the capacitor off the high voltage transformer that supplys the b+ to the vertical output IC. A repair person should be able to give ya a ball park on the cost as Im thinking somewhere from 85 to 135 Bucks depending on if theres only one cap goiung bad or could be a couple or more starting to dry up. So its your ball now .. Do you wanna spend that much to repair the set Do you like the set? is the set over 3 to 5 years old? Its up to you. Good Luck
Jun 03, 2006 | Orion STV2763 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
