Question about Yamaha P4500 Power Amplifier 2-Channel
Yamaha p4500 protect lights do not go off at power up
When i power up the amp, the protect light comes on and does not go off. Ive left the unit on for some time and nothing changes. The amp is not connected to anything at the moment so there cannot be any short circuits or anything although when i originally removed the amp i realised someone in the venue had taken the speaker connectors out of the speak and twisted them together!!
Any idea how i reset the amp?
  • devilofadj Dec 02, 2008
    the amp is no longer connected to anything - i have it at home now, just plug it in with nothing attached and the protect light comes on and stays on .
    The wires i untwisted straight away of course in the club! We have a different amp powering them now and its all fine
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
You only normally get that when the Volume over peaks, and the amp will automatically cut out to prevent it fron blowing the whole P.A up.
If you know it was working fine before the wires were twisted together, then best try undoing what was done, and making sure that the Amp's Volume is turned down to minimum.
Posted on Dec 02, 2008
  • Gav Shaw Dec 02, 2008
    Actually I just managed to find the User Manual for it :-), it's in PDF format, so you'll need to download and install Adobe Acrobat Reader if you have not got it already.
    You can download the Manual from here >
    http://www.yamaha.co.jp/manual/english/r...
Power supply output for Yamaha p4500 secondary output for the power supply so that i could check the voltage
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
Oct 17, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Yamaha p4500 in protection mode
The manual says the heat sink is too hot or an unacceptable DC voltage was sensed going out.
http://www.retrevo.com/support/Yamaha-P4500-Amps-manual/id/962bh144/t/2/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Oct 07, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Hi We have an Allen & Heath Mixing Desk connected to two Yamaha P4500 audio amplifiers (via graphic EQ and compressor/limiter) which power the 4 main and 4 side speakers in our church. We now want to...
'Splitting' leads is never the best way to distribute a signal. The best solution is to use the parallel inputs of the Yamahas to chain them together: mixer to amp1, amp1 to amp2, amp 2 to the Cloud. You should only need to use one input on the Cloud to drive all the channels, using the input switches at the rear.
Let me know if you need any clarification on this.
Sep 21, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Protection signal is permanently one. Non output sound.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 03, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Yamaha p4500 keeps blowing both ET5AH250V fuses help?
Suspect an overload in the power section, or more likely the main amp. A semi-conductor device is now acting like it was a piece of wire. Easy to spot with an ohm meter, it will just like you have touch the test probes together! My guess it will be one or more of the things on the big heatsink that's gone.
Jan 24, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Shashij_2001@yahoo.com
TURN THE BALANCE CONTROL IN THE MIDLE
Jul 06, 2010 | Yamaha P4500 Power Amplifier 2-Channel
One channel does not receive signal as shown by the led.oudtput stage is perfect the amp is a Yamaha P4500 poer amp
Try reverse connecting the channels, in order to locate where is the problem; at the cables or at the amplifier.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 06, 2010 | Yamaha P4500 Power Amplifier 2-Channel
My Yamaha P4500 burned my speakers rated 500 watts.The clip lite did not lit, so I pressumed it is operating normally
Chances are your speakers were "fake rated" as are most consumer quality speakers.
Unless the speakers were rated for CONTINUOUS power at 500 watts each you could easily destroy them with that amp.
Check the DC bias out of the amp. If it is under a volt, your speakers were fake rated.
This fake rating is to sell speakers and depends upon average music programing that does not have continuous high level.
Get professional speakers in MATCHED cabinets that have CONTINUOUS pwer ratings above what the amp can produce. ALSO suggest you put fuses in your speaker leads to protect the speakers.
WITHOUT proper cabinets, the speakers can be blown.
You should probably get a sound level meter to check that you are not damaging your ears. No fun in later life requiring expensive hearing aids! There are professional quality meters for about $140 on eBay.
Nov 02, 2009 | Yamaha P4500 Power Amplifier 2-Channel
Fans Not Coming On, Yammy P4500 Power Amp
Hi...
It could be on a thermostat inside. I would check the connections to the fan.It might have it's own fuse.
If you have a meter ,you can check for DC volts to the fan and continuity on the thermostat (if it has one)
2 leads mounted on the heatsink ..usually black and round with slide-on terminals
Apr 02, 2009 | Yamaha P4500 Power Amplifier 2-Channel
Yamaha P4500 Power Amplifier 2-Channel Logo
327 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
