Question about Pioneer AVIC-N2 DVD/CD/navigation receiver with 6.5" monitor Car Video Player
No picture on display, buttons dont work
Some times there is a picture on display, sometimes not and no any buttons work(except the volume). Touch screen working.
This is AVIC-N2 Navigation DVD/CD?Radio
Any Pioneer- recall for this model?
Thanks for help.
  • migi31 Dec 02, 2008
    Thanks so match! I'll try to contact to Pioneer, because I did not find any information in Inet about this recall.
    Thanks again.
    Michael.
  • 111 Answers
The problem is the ribbon cable,and you right there is a recall for this model,you need to contact Pioneer at pioneerelectronics.com and they should repair it for you at no cost.
Posted on Dec 02, 2008
I have problems with my quick touch buttons. The volume will adjust itself randomly, locking the mouse etc.. Also the wifi button will stop responding sometimes and randomly start working again.
Try this,
1. Click combination of buttons on your keyboard Windows+R -> Type MSCONFIG -> OK -> Continue -> Go to Startup Tab in the System Configuration -> Uncheck "HP Quicktouch On Screen Display Item" -> Restart Your computer.
It disables the on screen display of the volume control.
If this helpful, please give a testimonial and vote by pressing button four thumbs up
icon.
Sincerely
Thiyaga.
Aug 28, 2011 | HP Pavilion dv4000 Notebook
No sound on the speaker.
common issues with no notebook sound are volume physical switch turned down. mute sometimes checked off under the speaker by the clock some laptops have a Fn button that corresponds with keys either on the numbers or F keys above. look for anything that would work with a Function key combination (often in a blue color) printed on the keys themselves. another common issue is , in the control panel under sound /sound properties people sometimes tick of the "Digital output only" which effectively mutes the speakers. one last thing. sometimes on laptops volume settings dont look like buttons , but are responsive to touch. look for a volume slider image and play with that too. hope that helps, cheers.
Aug 26, 2010 | Acer Aspire One Netbook 8.9" Notebook
Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Oct 05, 2009 | Garmin Nuvi 680 GPS Receiver
HTC Touch Diamond - Powers up and down while plugged in
from a power off device.
press and hold the center joystick button, and the volume down buttons.
dont leave those two!
and now power on the device. wait for a gray screen asking you to make a clean boot. press the volUP or volDOWN button and after about 5 minutes your device will make an hard reset (clean boot) and will restore it to factory settings.
good luck!
Aug 29, 2009 | HTC Touch Diamond Smartphone
Acer Aspire 6920 touch volume not working
aright what you gotta do is open up the "launch manager" which enables all the buttons found on the multimedia area plus else where to work perfectly. this even lets you program which applications you want to have when you press the other buttons
Jul 23, 2009 | Acer Aspire 6920 Notebook PC
Light-up volume bars on the hp pc notebook dv7 1132nr
Hi Folks....
If you are talking about the Quick Launch buttons of the Notebooks from where we usually increase, decrease or mute the Volume, the lights will be still and will not increase or decrease with the increase or decrease in Volume.
However, you do have a utility which should be preinstalled in Notebooks called HP Quick Touch which shows the bars on the Display when the volume is Increased or Decreased  using the Quick Launch buttons. This application is not compatible with Windows Vista 64 bit edition.
The HP Quick Touch application is available for download from the link below :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe
Save the file in the Notebook and double click it once the download is completed to install the application.
Hope this helps....
Dec 20, 2008 | HP Pavilion dv4000 Notebook
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
Argh! Problem with my Creative Labs ZEN TOUCH 20GB MP3 Player
this is a common problem try this:
smacking the player on its rhs while turning it on works.I had to smack it fairly hard though so don't be afraid!! I
Nov 11, 2007 | Creative Labs Zen Touch MP3 Player
Buttons dont respond correctly
Sounds like one or more of the keypad buttons are sticking - That would also cause the remote control to stop functioning.When you saw "P:0 V:0" you somehow managed to put the tv into the service menu. Pull the keyboard away from the plastic buttons and make sure nothing is in the way.
Aug 22, 2007 | RCA P52929 52" Rear Projection Television
Pioneer AVIC-N2 DVD/CD/navigation receiver with 6.5" monitor Car Video Player Logo
406 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
