Question about Uniden 5.8GHz Dual Cordless Phone
Interference on recorded messages.
Most messages start out clear for the first few seconds, then pick up terrible interference, making them impossible to understand. We have exchanged the phone once for a new one, but are still experiencing the same problem. The old uniden phone we have works fine without any interference problems. Any ideas to fix this?
Thank you for your help.
"I" only charge a simple membership fee of $19.95 to share my "PREMIUM ASSITANCE PLAN" success. I am so sorry that I wasted your time, and my time, for a simple question. Lessons to you in the future- don't expext anything for free. My problem is solved, without any help from your solution, that I never got because of money issues. I didn't use any help topics or pay for them, so I am money ahead! So much for my warranty, right? All I did to fix this problem was......?
Sincerely, the problem solver,
Mike
Posted on Dec 03, 2008
Interference noises
you have an unclean power supply when you accelerate the whining sound gets louder this innerferance is coming from the alternator, to fix you need to purchase and install a p1 ground loop isolator but before you try this check to make sure your unit has a good ground, move it to a diff. location.
Jul 13, 2010 | Kenwood KDC-C467FM 6-Disc CD Changer
Will not accept incoming faxes
Have you set the Fax to Auto-answer or is it waiting for you to manually answer the fax? Change this by pressing Setup and Press 3, Press 3 again. Press the right arrow to toggle On or Off.
Make sure that the rings to answer is set appropriately. Press Setup 3 4 to change.
If you have a PBX or ISDN converter phone system, check that you are using the correct phone jack - for phones and faxes.
Do you have a voicemail service on the line? This will force you to receive faxes manually and only when you are present.
If you have an answering machine connected to the line, check that the answering machine is not the problem by disconnecting it and trying to receive a fax. Long welcome messages can make the calling fax machine hang up early. Insufficient time between the end of the message and the beep can make it impossible for the OfficeJet to spot the fax tones; the same is true with loud messages.
If this is the problem, record your message again, keeping it short (10 seconds but speak softly and slowly).
If you have a distinctive ring on the fax line, make sure that the OfficeJet is programmed to recognize the ring (some ring patterns cannot be interpreted and you'll need to contact your phone company to change it).
Check that other computer hardware is not causing an issue (modem with auto-answer, other interference). Unplug everything except the OfficeJet and try to receive a fax to check for interference. Then reconnect one item at a time and try getting a fax again to determine which item is causing the probelm.
I hope this helps.
Apr 08, 2010 | HP 5510 4-in-one Printer
Wifi interference??
The short answer is that it could interfere with the wi-fi, but your wi-fi should not interfere with your phone because it uses WDECT, "wide-band digitally enhanced cordless telecommunications" engineering. No matter how tight the bandwidth is on any RF transmission, power, proximity, and harmonics all play a roll. Ideally we want the power from our transmission to occupy the target frequency but the reality in RF is that this is nearly impossible without DSP filters. I have pasted some extra info below to help answer this question.
Digital Enhanced Cordless Telecommunications
(DECT), known as Digital European Cordless Telephone[1] until 1995, is an ETSI standard for digital portable phones (cordless home telephones), commonly used for domestic or corporate purposes. It is recognised by the ITU as fulfilling the IMT-2000 requirements and thus qualifies as a 3G system.
The four most common frequencies today are 900MHz, 2.4GHz, 5.8GHz and DECT 6.0:
900 MHz Currentlythe most common frequency for cordless phones, 900MHz phones may offera greater range than other frequencies. However, the 900MHz spectrum iscluttered and may result in interference with baby monitors and other900MHz cordless phones. Radio scanners can also easily pick up thisband. 2.4 GHz 2.4GHzphones offer better clarity and security than 900MHz, but mayexperience some interference with microwave ovens and wirelessnetworking (wi-fi) products. 5.8 GHz Themost advanced cordless phones available, 5.8GHz phones transmit on anew, open frequency and have the least chance for interference. Theywill not interfere with wireless networking (wi-fi) products. DECT 6.0 DECT6.0 operates on the 1.9GHz frequency. Though newly approved in the US,this frequency has been used for many years in Europe and can increasecall clarity and security. The wi-fi friendly DECT technology easilyintegrates into homes with wi-fi and internet services because the1.9GHz frequency is exclusive to DECT, making it interference free forcordless communications.
Jul 19, 2009 | Uniden Lands Phones
Interference when recording in NTSC
You need to check your audio and video cable and make sure it is properly connected. Now if you found that there is no problem with your cable that is the time that you need to return the device to your reseller and asked for the replacement
Jul 06, 2009 | Pinnacle Dazzle DVD Recorder
Radio interference
That sounds like its the cable. I make my own cables so let me know if you'd be interested. They have a copper shield with a polymer that blocks out noise.
Jun 18, 2009 | Music
I'm experiencing problems with a Panasonic DMR-EX87 DVD recorder that is less than 6mths old. In the last few months while watching programs recorded to the hard drive, the picture often breaks up in the...
My guess is that your DVD player is malfunctioning. I'd check the warranty and just try and get another. The problem you're describing sounds like the DVD hardware is probably messed up.
May 23, 2008 | Panasonic Televison & Video
Clicking noise on all handsets upon pick-up
could there be interference ?
Severe noise interference.
• Keep the handset away from microwave ovens, computers, remote control toys, wireless
microphones, alarm systems, intercoms, room monitors, fluorescent lights, and electrical
appliances.
• Move to another location or turn off the source of interference.
Or maybe the unit is recording the calls, this is accompanied by an alert tone or click.
Mar 21, 2007 | Uniden TRU8885-2 Cordless Phone
Sound Interference
NO it dosent sound like there related problems at all. Now you say you get interferance or is it more like a static noise only when using the dvd player??? If thats the case then you have an output device problem as its breaking down and crackling into your input to your sound amp or the tv. Its a problem that will need to be traced with a scope and a test disk. as it could be a D to a converter or an op amp IC, or even as simple as a filter cap. Good Luck
Apr 10, 2006 | JVC DRM10 DVD Recorder
Uniden 5.8GHz Dual Cordless Phone Logo
43 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
