Question about Whirlpool GS460 Gas Kitchen Range
My Whirlpool Gas oven has started to burn everything
Whirlpool Gold gas range 3 yrs old modelGW395LEPS00 has begun to incinerate and burn whatever I put in it. It is so hot I can barely remove the pans from the oven. It has displayed an error message after I remove the stuff from the oven. Can you help?
  • 473 Answers
First, tell me what error it showed so we can get to the bottom of the problem
Posted on Dec 02, 2008
Is there information on a Whirlpool Gold Gas Double Oven?
Repairs on gas cooking appliance's can only be carried out by someone deemed competent please use a registered gas fitter for this repair.
Sep 06, 2014 | Whirlpool Gold Double Oven Freestanding...
Wfg361lvs oven clicks 1 times, lights and then clicks three more times and turns off.
manually check the burner and the gas jet area for blockage that would prevent lightup.. the safety is kicking in to prevent gas explosion..
Jan 12, 2014 | Whirlpool WFG361LVS Stainless Steel Gas...
On my whirlpool gas range only 1 burner out of 5 will ignite. oven light works, oven ignites. only 3 months old and worked fine until now.
Most often when cleaning, soapis left behind and obstructs the flow of ignition gas normally directed at the exact point of the spark. Check this area and use a small wire brush to clean these area of the burners that do nto work. Let us know if this helps. Eric Campion
May 19, 2012 | Whirlpool GFG461LVS Stainless Steel Gas...
Whirlpool Gold GS 445LEMS - All digital functions work, but the oven no longer heats up. It "clicks" after you press bake, then start, but it doesn't go on. The oven is about 3 yrs. old.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Oct 30, 2010 | Whirlpool Gold GW399LXU Gas Range
Whirlpool Gold gas stovetop ignition stuck to on
Pull the knobs off and use a hair dryer blowing down the gas valve stems to dry out the spill. They should be fine once they are dry.
Jan 01, 2010 | Whirlpool Gold GW399LXU Gas Range
My whirlpool oven is over heating the range is about 5 yrs old.
thermocouple is defective inside oven cavity on roof of oven
Nov 06, 2009 | Whirlpool GS460 Gas Kitchen Range
Oven will not come on
whirpool gold gas stove tops not lite up
Aug 24, 2009 | Whirlpool Gold GW399LXU Gas Range
Whirlpool Gold oven is locked
Had to switch it off at the breaker, wait for it to cool down, and switch the breaker back on. Then it unlocked. In the meantime, however, our french fries were completely incinerated, and the house filled with smoke.
Jul 28, 2009 | Whirlpool SB160PEE Gas Single Oven
Whirlpool gas stove
Replace the regulator on the gas line.
Jan 01, 2009 | Whirlpool SF325 Gas Kitchen Range
Whirlpool GS460 Gas Kitchen Range Logo
273 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
