Question about Whirlpool Dryers
My Whirlpool, LER6620PQ1 dryer will not stop running, nor will it heat at all. What could be the cause? Since both issues began at same time, I would think it is a similar cause.
  • 172 Answers
Try to put the dryer on a timed cycle and see if the timer will advance. If you have the dryer on an automatic cycle and it is not heating it can run for a long long time. If the timer will advance in a time cycle you may just need to check your thermostats and the heater on your dryer. To do this pull the dryer out and unplug it, then take the back off. You will need a voltage meter to continue. Check the voltage at the plug and make sure you have two seperate 110 volt legs and 220 volts across. If the voltage is correct check the heater for continuity and make sure it is not grounded. Then check the thermostat on the top of the heater housing. If all of these parts are good and you have the proper voltage you will need a new timer
timer # 8299778 $74.00 shipped to you.
heater # 279838 $63.00 shipped to you.
thermostat kit # 279816 $40 shipped to you.
Gool luck to you and let me know if you need a part.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Dec 02, 2008
How do I go about cleaning the heat exchanger on my Tumble Dryer?
Posted on Oct 24, 2009
Whirlpool dryer ler6620pq1 starts and dries fine..however, you have to place something in front of start knob or it shuts off. works normally as long as something in holding start knob in
There are centripetal contacts in the motor that have to work or the motor wont stay running (spinning).
CHECK THE POWER IN YOU BREAKER BOX.....
220 volt dryers have 1 (large) breaker or 2 (small) breakers (tied together) in you breaker panel. If there are 2 breakers tied together, it is possible that only one has tripped causing you to lose a phase. That could cause weird issues like you are experiencing. Try turning off this (double) breaker and then back on again.
If it's still working the same way you may have a bad motor. Check the parts / troubleshooting site below if it's still not functioning properly.
" If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. "
Dec 01, 2014 | Whirlpool Dryers
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
Whirlpool dryer LGQ7030KQ1 won't run the dryer won't run when the start button is pressed. Later we had it in the off position and the 30 minute wrinkle cycle was set to on. Suddenly it began to run. So...
Hello there, I would try removing the control panel and check for broken wires in which mice we'll get in there and chew them. This is what happened to me.
Aug 02, 2017 | Dryers
Clothes dryer will not start
sounds as if your motor has tightened-up or seized from heat and age bearing failure which it would cause excessive current draw at start-up if you can access the motor unplug unit then remove belt and spin motor pulley is should turn freely and coast to a stop if it seems tight the bearings are dried out
Jul 12, 2009 | Whirlpool Dryers
Dryer won't heat.
Hi, THe heating element is located in the back of your dryer. UNPLUG the dryer. Remove the back panel and you will see the element on the right hand side. If you have an ohms meter, check continuity on all the thermostats and the element. If any of them have no continuity, it will need replaced. Please let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer not heating
There is many different things it could be! most of the time it is not the heating element. You have thermal fuses and safety switches. I bet you 10 to 1 if you locate the thermal fuse on the element cannon say 1 foot up from the incoming voltage from the wires to the heating element.
1. either disconnect power to the unit, take continuity on every fuse try the one i suggested first.
2. the same exact fuse im talking about disconnect power and connect both wires together, dont ground it out, plug power back in and then try it.
Note this is only advice and Whirlpool Parts Surplus is not responsible. Try that give us a call or hit that link and find your thermal fuse part number.
Apr 17, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LTE5243D Top Load Stacked Dryer heats sometimes and not others
couple things this could be lets start obvious
faulty door switch even though door latches doesnt mean its working properly
bad guages easy to check dont have to run dryer just guages
turn on setting let run threw cycle if it stops on cycle and dont move for a length of time this will be the problem
these 2 things are main causes of why a machine wont work or partcially works at times everything else is easy
Nov 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
719 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
