Question about Kenmore 15218 Mechanical Sewing Machine
Fabric wil not feed thru machine
I actually just bought a model#18221 Fabric will not feed thru machine. It is properly threaded from top and bobbin, feed-dog is up and moving, foot pressure is at 3, stitch length is on 2 but when I start to sew the fabric stay in one place. I can gently pull thru but will not move on it's own. I am trying to familiarize myself with the machine and test proper stitch tension. I am not a novice machine user but this has me stumped!
  • gofarm1994 Dec 04, 2008
    Thanks, I found out the problem was an incorrect setting on the stitch selector. It was set on SS instead of 2SS., When changed the problem was resolved but, when moving the feed-dog into a dropped position via the slide on the free-arm it will not return to the up position by returning the slide to the left. I have to remove the entire plate from under the foot and use the screw driver to gently lift it up and then it clicks into position. Am I doing something wrong?
  • 125 Answers
Adjust your feed dog hight. manual shows u how
Posted on Dec 02, 2008
I have a Baby Lock Audrey. The bobbin thread is "nesting". I have tried rewinding the bobbin and rethreading the needle and bobbin thread but that hasn't helped.
Check that it is actually the bobbin thread that is nesting. Generally, bobbin thread issues appear on the top of the fabric and upper thread issues appear on the underside of the fabric.
If it is in fact the bobbin thread, the bobbin thread tension may be off or malfunctioning.
If it is the upper thread nesting under the fabric:
1. Remove the thread
2. Install a brand new needle
3. ALWAYS RAISE the presser foot. This releases the thread tension so the thread will seat properly.
4. Rethread from the beginning and check the thread path is correct.
5. Set the upper tension at the midway point.
6. Check that the bobbin thread is loaded properly
7. Retest the machine.
If it continues to create thread nests under the fabric, tighten the upper tension.
Jun 22, 2016 | Baby Lock Sewing Machines
My bottom stich is longer than my top switch. What setting do I need to change?
if your saying that the bobbin loop is too large , 1st ck your bobbin tension clip ,(tiny spring clip with screw on it) thread should slip thru using three of your closed fingers in a over/under arrangement as a puller if you have correct tension , next ck your main tension , lots of times I see thread pulls its from the main tension is too tight for the fabric being used (this one needs to be adj for each fabric ? and it pulls thru fabric making it bunch up under presser foot
Feb 09, 2016 | Sewing Machines
My bobbin thread continues to bunch up on the back of the fabric.. How can I fix this?
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
3 Common Sewing Machine Problems and How to Fix Them
Dec 29, 2015 | Sewing Machines
My machine doesn't sew. When I start sewing it seems like the material isn't moving but at the same time I see that the threads haven't connected.
check for broken drive belt that works the bottom shaft in the machine
have a sewing machine service center service it
Nov 07, 2015 | Brother Sewing Machines
I have a Pfaff 4.2 Quilt Expression. I am free motion quilting and the bobbin thread keeps hanging up. Any suggestions?
1. The top loading bobbin cases have small brackets to keep them from turning or moving up or down.
2. Adjust brackets with small screwdriver. Allow enough room for thread to flow through.
3. Rotate hand wheel both directions to make sure the bobbin case doesn't move around. Also, watch the thread to see if it is flowing across the top of the bobbin case.
4. You may need to slow down movement of your "free motion". Also, make sure you are using the right pressure foot.
Mar 20, 2015 | PfaFF Sewing Machines
Top thread will not work ive tryed changing needles is there a special needle to use
the needle used depends on the fabric being sewed. the needle must move thru the needles eye smoothly.
make sure the machine is threaded correctly, using every thread guide
make sure also the bobbin is wound correctly and that the bobbin is inserted into the bobbin case correctly, if the bobbin is turned the wrong way the machine wil not sew
here is a link for a free manual, if you don't have one
http://www.singerco.com/uploads/download/756_white-3300-emb-x.pdf
Sep 07, 2013 | White Sewing W3300 Computerized Sewing...
Machine will stitch for a few stitches and then stop and beep.
Your problem is most likely that you've run out of bobbin thread (or about to and the bobbin thread is now loose around the bobbin), your top thread is broken/about to break, or you have a birds' nest (a messy knot of thread) forming underneath the fabric/presser foot and/or within the feed dog. Upon occasion, it's a false alarm. Remove the fabric from the machine and clip your threads. If your bobbin and top thread are fine, place your fabric back in and start sewing again. If you get the stop and beep again and the threads remain unbroken, try rethreading both the top thread and the bobbin. Should you still get the alarm, hit the button to start and see if it resolves itself after a couple of tries. If it doesn't, afraid you have a problem I haven't encountered yet. But so far, the above steps have always resolved the problem for me in the last 6 years.
Mar 04, 2011 | Singer CE-100 Futura Computerized Sewing...
Pfaff sewing machine 1469. Does not pick up bobbin thread. Large loops of top thread on bottom of material.
make sure you have it threaded correctly,and also check and make sure you have the needle in correctly.The flat part of the needle goes towards the back.(away from you).Also double check that the bobbin is in the proper way and is going thru the tensions it needs to go thru.
pull your threads to the back of fabric, hold together & hold until you've stictched an inch or so.
The thread from the bobbin should start to creep up towards the feed dogs and make a loop that the needle and thread can "grab" to pull it up thru the hole for stitching. You might want to slowly put the needle down thru the feed dogs and then slowly with the winder not the pedal but with the winder slowly bring the needle up again. Try this a few times and see if the needle and bring it up. try it couple of times to get it right.
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Nov 30, 2009 | Sewing Machines
Kenmore Sewing Machine Drop-in Bobbin Tension Adjusting Problems
looped stitches are usually caused by improper tension. when the loop is on the upper side, it may be corrected by loosening the top tension or by tightening the lower tension (turn the tension screws on the bobbin a hair at a time)
since using the machine only a few times it is best to clean the machine from dust (can use a can of air) blow air into the bobbin area and between the tension disks and under the throat plate.
make sure the machine is threaded correctly and bobbin is evenly threaded
Aug 26, 2009 | Kenmore Sewing Machines
Timing
Question: How does one find the tension discs??? I have a White 1740 with a top drop in bobbin and I went thru the same problems as night_wolf above, then, ultimately, the top thread will now not pick-up the bobbin thread through the fabric. It picks up the bobbin thread without fabric in play, but once fabric is added (for free motion quilting) it won't pick it up. This is after using the machine for the last 10 days to piece and quilt without a problem until this morning.
I'm at a loss.
Tks, Candace
Jan 17, 2008 | Brother LS-2125 Mechanical Sewing Machine
Kenmore 15218 Mechanical Sewing Machine Logo
347 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
