Question about Samsung Prostar 816 Phone
Date & time.
Once i entered #06 it says mmc enabled/disabled. i was wondering what that meant, and how to reset the date and time. and where to enter the password.. thanks.
  • 32 Answers
To reset system time you must be at the attendant station and with the handset cradled:
Dial: #06 4321 1 # (4321 is the default password)
Then:#55 YY, MM, DD, W, HH, MM, # time will be saved and phone will go back to normal operation.
Naming convention:
YY - Last two digits of the year
MM - Month (1-12)
DD - Day of month (1-31)
W - Day of Week (monday = 1.... sunday = 7)
HH - Hour (24hr format)
MM - Minutes (00-59)
ex: To set the time For Monday, Jan. 5, 2009 at 8:31pm I would enter: 09 01 05 1 20 31 #
Good Luck,
BB
Posted on Jan 06, 2009
How do reset the time
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Date and Time Settings Pantech Marauder
Nov 01, 2015 | Pantech Cell Phones
Hello we have a Brother 2820 Fax Machine and we cannot find the Instruction Manual and we need to reset the time can you please advise us on how to do it. Thanks Marie
1Press Menu/Set, 0, 2.
2 Enter the last two digits of the year. Press Menu/Set.
3 Enter two digits for the month. Press Menu/Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day. Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format. Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time whenever the machine is idle in Fax mode.
When the machine is in Sleep mode, the LCD shows Sleep. (See Sleep Time on page 2-8.)
Hopefully that worked correctly and solved your problem!
Apr 07, 2011 | Brother Office Equipment & Supplies
OUR PROSTAR 816 SYSTEM IS RINGING BACK ONCE WE PUT SOMEONE ON HOLD WAY TOO QUICKLY. IN ABOUT 30 SECONDS IT WILL RING BACK & i'D LIKE TO CHANGE THE RING BACK TIME TO AS LONG AS IT WILL ALLOW. CAN YOU...
To change the hold recall timer on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
press # when finished
Aug 13, 2010 | Samsung Prostar 816 Phone
How can I Program the time and date
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
Jun 08, 2010 | Samsung Prostar 816 Phone
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
How do I reset clock?
Press the Transfer key
Prompt: ENTER PGM ID: Enter 200
Prompt: PASSCODE: Enter 1234
Display shows: DISABLE
Press 1 to change to ENABLE
Press the Speaker key
Enter 505
Current Date/Time shows in the format: WMMDDYY:HHMM
W=Week day where 1 = Monday, 2 = Tuesday etc.
HH = Hour in military format
Enter a new Date/Time in the same format. noce the last digit is pressed it will automatically save.
For example: 3102908:1645 is what you would enter for Wednesday, October 29th, 2008 @4:45pm.
Press the Transfer key to exit.
Nov 02, 2009 | Samsung DCS 12 Corded Phone
How do i change the time on my samsung prostar 816 phone?
  1. Enable technician programming mode
    • Press "#" - "PROGRAMMING" is displayed
    • Dial "20" - "MMC ENABLED" or "MMC DISABLED" is displayed
    • Dial the password (default - 1234) - if wrong password is enter "ERROR" is displayed
    • Dial "1" to enter program mode
    • Press "#"
  2. Press "#" key - "PROGRAMMING" is displayed
  3. Dial "55" - the display shows "YY MM DD W HH MM" and then the current date is displayed
  4. Enter the new date
    • YY = Last two digits of the year
    • MM = Month (01 - 12)
    • DD = Day of the month (01 - 31)
    • W = Day of the week (1 -7 day of the week begins on Monday & ends on Sunday)
    • HH = Hour (Use 24 hour clock)
    • MM = Minutes (0-59)
  5. Press "#" - new date is saved
Jul 24, 2009 | Samsung Prostar 816 Phone
PROSTAR 816 PLUS
First to change the clock to a 12 hour instead of a 24 hour requires a bit of CAUTION. You have to go into the technician level of programming so be careful. From a display phone, Press #, ( Programming ) is displayed, enter 20, ( MMC Disabled ) is displayed, enter password ( 1 2 3 4 is default ), enter function 4 for 12 hour clock, enter # to exit. If the time and date are displayed wrong you have to go to # 55 and reset time and date.
YY MM DD W HH MM format. W = Day of week with 1=Monday and HH MM must be entered in Military time even though you have a 12 hour clock set. Good Luck
Jul 02, 2008 | Samsung Prostar 816 Phone
Set time and date
hit the feature button (gray, looks like a globe on it) under the display, under the 3 gray buttons in a row.
then **8463
password is 23646
follow prompts :)
hit the hang up (phone with arrow underneath) when fone.
Jan 22, 2008 | Lands Phones
Setting date/time display
First, you have to Enable Customer Programming. - With handset on-hook, dial #06. The display shows [MMC DISABLED]. - Dial the passcode and '1' and then dial #. (If you don't know the password try 1234, 4321, 9999, etc.) At this point, customer programming is open... Next, Setting the date and time. - Dial #55. Display shows [YY MM DD W HH MM]. - Dial new information as follows: YY = Last two digits of the year MM = Month (01-12) DD = Day of the month (01-31) W = Day of the week (1-7; week begins on Monday (1) and ends on Sunday (7)) HH = Hour (use 24 hour clock) MM = Minutes (00-59) - Dial # to set current date and time. The phone returns to normal use.
Oct 30, 2006 | Samsung Prostar 816 Phone
Lands Phones Logo
131 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
