Question about Whirlpool Ovens
Bake will not heat up to where it should
Hi, my oven is approximatley 5 years old. When I turn the bake on it will not heat up to where it should. It will not cook anything from the bottom. The broil still works as well as the stove top, just not cooking from the bottom. I have replaced the bottom element with a new one and still not bottom heat. Any other suggestions? Thanks in advance
  • aramat_77 Dec 02, 2008
    My husband had went through everything with a multi metre and it all seems to be producing conductivity, but I will take the element out and have it checked. Thank you for your time and suggestions. If you have any others I would love to hear them. I will let you know what I find out. Thanks again. :)
  • aramat_77 Dec 07, 2008
    I had the element checked and it seems to be fine. Is there any way to check if the t-stat is working before I buy a new one? Again, thanks in advance for any help or suggestions you may have! :)
  • 306 Answers
If the oven is getting warm but not as hot as it should your thermostat is bad. They are a small pain to replace but can be done if you don't mind removing the front panel and removing 2 small screws. It would be best to get your model number and remove the thermostat to get exactly the same one. Let me know how it turns out. Ken
Posted on Dec 02, 2008
  • Ken Bledsoe Dec 02, 2008
    After thinking more about this problem t-stat might not be the problem the heating element would be my first thing to eliminate if you have a volt ohm meter ohm the element to determine that it is bad. If not sure take it out and go to parts house and they can check it for you.
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Have just moved from UK and we don't have broil and bake on our ovens - what do they mean/what's the difference as I've been cooking garlic bread on bake but it's taking twice as long to cook?
The broil is the top element and the bake is the bottom element...so with broil you are heating from the top and with bake you are heating from the bottom...if your oven has a fan, turn that on with a bake setting and it will speed up the process..
heatman101
Apr 20, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I have a 5 year old Kitchen Aid duel fuel slide-in range. I have used clean twice since I got it. I tried to start clean today and it all went fine until I noticed after about 30 minutes that it was not...
Hi Cynthia
F5 error code normally means control board or clock failure. It means you will have to have a new control board and clock fitted.
Dec 18, 2010 | Ovens
Jennair gas oven. lower burner won't light, i.e.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Jul 16, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven does not bake any more
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 01, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Top and bottom oven doesn't warm up.
we had a repairman come and he opened the electronic control panel and hit the "reset" on it and it worked after that. hope this helps. these ovens stink.
Jan 03, 2009 | Thermador C302U Electric Double Oven
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Oven temperature fisher paykel
benypeny what that flash was from what I have seen over the years is your heating element on the back wall burning out. Remove the cover and you will see the element is no longer in 1 piece.
Feb 03, 2008 | Ovens
OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Nov 24, 2007 | Ovens
Ovens Logo
103 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
