Question about Canon PIXMA MP130 All-In-One InkJet Printer
Canon pixma mp130 printer
My printer is telling me that I have a cartridge jammed therefore not letting me do any printer. Any ideas on what I can do to rectify this problem without having to buy another printer. Thank you to anyone that can help me.
  • 2 more comments
  • meelko Nov 10, 2007
    Same problem.... printer refuses to work.
  • ettruji Dec 23, 2007
    I have the same issue. Does this need to be serviced or just pitched?
  • ghasle Jan 15, 2008
    same problem, tried taking cartridge in and out but still "jammed" .... WHAT is jammed?
  • Anonymous May 04, 2009
    Will not print. It says cartridge jammed. Fixed it once by turning it off and unplugging but that doesn't work any more
    Problem Solver:
  • 6 Answers
Tried that and it doesn't work
Posted on Feb 05, 2008
  • chocoicemmm Feb 05, 2008
    What i did was press the stop button after it "failed" to print. You should see no red blinking "alarm".
    Instructions:
    a) Press the "menu" button until you reach (7. User data)
    b) Press the right arrow until it says "2. Maintenance"
    c) Then press the "OK" button
    d) Double check that it reads Maintenance: Nozzle Check before pressing OK
    e) The printer will do its job, (rolling up and down)
    f) Hopefully the printer will be unstuck and print something showing somethign like a Ph indicator.
    g) If that doesn't work, please try it a couple more times, (it worked on the 5th time for me, experimental):)
    Hope it helps
    NOTE: It worked with my printer PIXMA MP 110, im guessing it'll work with the 130 model aswell.
Deseo el driver de pixma 130
Posted on Jan 22, 2008
Take the cartridge out, Put it back. It will work when it wants to.
My Canon Pixma MP130 keeps giving me the 5100 error. Can't even complete the nozzle print test. The ink cartridges do not appear to be jammed as they move. What is the problem? Please help.
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
May 22, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Mp130 cartrage jammed. computer message says that the paper is jammed. but their is no paper jammed.
The message on the computer is rather generic.. you will get a paper jam message for many different problems. the series of flashing lights on the printer is a more accurate way to tell what is going on. go to the troubleshooting section of the Canon website to get an accurate idea. Most likely it has a broken paper pickup shaft.
Sep 30, 2010 | Canon PIXMA MP130 All-In-One InkJet...
My canon pixma mp30 keeps saying cartridge jammed pls can you tell me if i can fix it cos it wont print. thanks
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
  1. You will include printer.
  2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
  3. select NVRAM ACCESS and further BY OK.
  4. select SET Abs- m level and advance value equal to zero.
  5. select SET Abs- r level (if there is) and also you will establish into zero.
  6. you will turn off printer by button POWER.
Dec 29, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon mp130 ink cartridge jammed
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 03, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I have a canon pixma mp130 and it keeps saying cart. jammed
Press menu to maintenance.....go to cleaning roller....repeat cleaning 3 times....return to copying...hope this helps
Aug 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Ink cartridge jammed
Canon FaxphoneB95 gives message"Cartridge Jammed". How can I solve this problem. Need Answer Urgently Please.
Dec 14, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Printer mp130
take the ink cradle out and take the cartridges out. clean the print head on cradle with alcohol, and you might wanna try blowing the ink residue out of the head becuase the black ink cartridge leaks
Jul 10, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
2,093 people viewed this question
Clive
Clive
old marine
old marine
