Question about Imperial IFS40 Deep Fryer
Lie up deep fryer
IM TRYING TO LITE UP THE FRYER BUT THE FLAME IS NO STONG ENOGH TO KEEP TH PILOT FLAME ON AS SOON I RELEASED THE PILOT BUTTON GOES OFF
    Novelist:
  • 125 Answers
Hello. Could be three things, from what you describe, it sounds like your pilot is dirty, and not heating the thermopile enougher, and pilot off to energize the pilot portion of the valve. You could also have a bad thermopile, and no matter how long you hold it, or if your pilot is good, will it energize the valve. The last thing is that your hi limit has failed, and is preventing your gas valve from getting any voltage at all on purpose, as it is a temperature actuated switch that will shut the fryer off it it gets too hot, it could have failed and is now keeping the pilot from coming on, some of these have a reset button you can push ( usually red ) that will reset it, but then why did it trip? either your thermostat is out of calibration, the bulb may be broken in the tank somewhere, or it may just be tripping too early, like 375, instead of 425 to 460 depending on spec.
Hope this helped, and thank you.
Posted on Feb 28, 2009
Trying to light the pilot light on deep fryer when i push button in it lights but when i let go of button pilot light goes out what am i doing wrong
If the pilot flame does not hold after releasing the button for at least 20 to 30 seconds, try to clean the thermopile and tighten all wiring connection on gas valve, thermostat and hi limit the repeat the process. The thermopile must be heated by pilot flame in order for it to generate small amount of voltage to open the pilot valve.
If this does not correct the problem, try replacing the thermopile.
May 24, 2011 | American Range AF45LP Deep Fryer
When the pilot light button is released the flame goes out. (pitco propane fryer) - unsure of model number as data plate is worn. Does the thermopile need replacing ?
Try first to clean the thermopile. If it has accumulated soot/ carbon, it will not sense enough heat from the pilot flame to generate small amount of electricity to energize the pilot valve and main valve of gas valve.
May 18, 2011 | Pitco Frialator SG14 Deep Fryer
I have a pitco frialator and the pilot will light but when button is released after heating thermocouple, it just goes out. I've replaced the thermocouple but still the same. The pilot flame is in the...
Check if the unit receives the right amount of fuel as stated on its nameplate, if it does, check all wires for loose connections, Milli volt wont pass on loose wiring. If this does not correct the problem, you have to replace the gas valve, the main valve coil may be shorted that's why the pilot is shut when main valve is energized.
Apr 30, 2011 | Pitco Frialator 35CS Deep Fryer
Hi i have a new imperial fryer and im tring to light it and cant seem to get it to work. any idea on how to get it working?
Have a lighter handy (I use one of the elongated ones for caravaners)
in-between the burners is a pilot light (top right) keep the lighter flame where the gas comes out.
On the right hand side of the fryer at the bottom is a gas valve with a little black knob.
Press and hold the black knob in and gas will come out of the pilot light and ignite by the lighter flame. You need to hold the button in for quite a while. (until it stays lit)
When it stays lit depress the little black knob and turn it anti clockwise. Gas comes out of the burners and ignites from the pilot light. When it reaches temp. it will cut out.
To turn it off turn the little black knob clockwise. To turn the pilot light off, push and turn clockwise.
Mar 04, 2011 | Imperial IFS40 Deep Fryer
Pilot light goes out
Two things to check. Make sure you have continuity through the terminals on the high limit. Also make sure you have a good pilot flame and the pilot generator is supplying over 500 millivolts. It's either the high limit or the generator.
Tom
Jul 15, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot won't lite. fryer is 6 months old. Did get pilot to lite once and as soon as we turned thermostat pilot went out.
When you turned on the thermostat you required more millivolts from the system and it failed. Low millivolts. That would tell you the pilot generator needs replacing. Make sure you have a good pilot flame hitting the pilot generator.
Tom
Jul 07, 2010 | Vulcan EF3 Deep Fryer
My pitco 28lb countertop gas deepfryer conv to propane it will l
Check if the flame quality of the pilot is good. Small amount of voltage generated by thermopile used in energizing pilot main valve coil during fryer operation relies on the quality of pilot flame, also, the thermopile itself should be free of soot or any form of dirt in order for it to absorb the heat from pilot flame.
Check also the gas pressure, it should meet the gas pressure required on the nameplate.
May 24, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot light won't stay lit.
Ensure that gas is getting to the pilot , or you may have a devective pressure regulator.
If gas is getting to pilot and pilot is turning off, then you need to replace the thermocouple.
The thermocouple function is to turn off the gas if there is not enough temperature, so to prevent gas leaks if the pilot light goes off.
Near to the pilot light there should a part similar to a small metal tube directly in contact with the flame. Thermocouple is wired back to the gas valve.
When the pilot is on, and temperature is steady, the thermocouple will generate a small voltage that will keep the gas safety valve open. In case the pilot light goes off, the thermocouple will cause the valve to close. When you hold the pilot light button , the thermocouple will normally reach enough temp to keep valve open.
If the termocouple is faulty, it will turn off as soon as you release the igniter button.
Replacing thermocouple is an easy repair.
Call the number listed on the owners documentation to get the replacement part.
Sep 05, 2009 | Imperial IFS40 Deep Fryer
I have DCS FSF-40N fryer. the piolet doesn't stay on when I release my finger it goes off I tried to change the gas valve from different brand and I only replaced small part where the electrical wire is...
You must first check to see if your pilot flame is good. If it is too weak, or not impinging properly on the thermopile, it will not stay lit. If the pilot flame is ok, the problem could be that the thermopile is weak. using a millivolt meter, test the voltage across the thermopile while the pilot is lit (you may need someone to hold the button down while you do this). You will also need to disconnect the thermopile's leads from the control while you do this. You should get about 750 millivolts across the thermopile while the flame is on it (let it heat for a while to stabilize). If your reading is too low, your thermopile may be shot and needs to be replaced. That is of course only if your flame is proper. That voltage is needed (or close) to keep the magnet open so it will stay lit when you let the button go.
Sep 04, 2009 | DCS FSF-40 Deep Fryer
Pilot goes out once button is released
If the new thermocouple was installed properly, with its tip in or across the pilot flame so as to be heated by the flame, then the control valve may be faulty.
Note: The pilot primer button may need to be held down for a longer period of time.
Aduz
Mar 24, 2009 | Water Heaters
Imperial IFS40 Deep Fryer Logo
143 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
