Question about GE Advantium 120 Convection/Microwave Oven
My microwave shuts off after a few mins. of use
My microwave/convection oven shuts off and gos completey blank after a few mins of use. it acts like it has no power but i know that the recpt it is pluged into works. this unit is in my rv and if i drive down the road and then turn power back on it works again for just a min and fades out if used... please help!! thanks
  • GE Master
  • 9,156 Answers
There seems to be a rash of these units failing in this way due to bad magnetrons. The magnetrons normally have a warranty that runs for a few years. In some models, they have a whole kit they replace, consisting of a new magnetron, stirrer, and high-voltage rectifier diode. I would call GE Customer Relations with your model and serial numbers to see if yours is affected. They're at 1-800-386-1215 (8-6 ET). I would also suggest you ask them for a referral to a GE-authorized servide center in your area. Good luck. I appreciate your thoughtful rating of this answer.
Posted on Jan 29, 2007
SOURCE:
When I run the my Sharp convection oven in the convection mode...it runs for about 5 min. at a time ..then stops....as soon as I hit start again it will run for another 5 minutes and shut down again. It....
Don't waste your money on unnecessary sources and unwanted repairs. Get this manual online under $10-15 and get complete guide on whether to repair or not, service it, and how to repair etc
Best Manuals
Mar 05, 2018 | Sharp R-930AK Convection/Microwave Oven
My Sharp microwave convection oven (R-967M / R96STM) cuts out during convection pre-heating and cooking, It appears it stops heating after 1 min. If the START button is pressed again the oven starts...
Also the fact it is a convection oven could mean the oven temperature sensor is not picking up the oven temp. it is not telling the machine it is there by the board seeing its resistance, the unit will shut off as a safety feature. The oven sees temperature by reading the value of a temperature dependent resistor. As the temperature changes so does the value of the component ( oven temp sensor) that way the unit determines the temperature inside the unit. Sometimes those sensors will break since they are in the area with the heat and moisture, they get old and break.
Aug 17, 2017 | Sharp Microwave Ovens
Microwave works, but not the fan. Then shuts off
The internal cooling fan (blower) is faulty and will need replacing.
Dec 28, 2009 | RCA RMW729 Microwave Oven
Sylvania microwave convection oven overheats after
you need to remove the cover and after it operates and shuts down(CAREFULLY) feel the magnetron tube sides (BE EXTREMELY CAREFUL<HI_VOLTAGE ON TUBE FROM CAPACITOR) still, then if its not too warm there is a small temp sensor held by 2 screws on the side of the tube and they can go bad and shut off current to the tube,the tube will run warm, but should never run HOT,if its hot its defective
Oct 28, 2009 | Sharp R-353 Microwave Oven
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
Changing the convection temperature
keep pressing convection symbol a few times this brings it down
Jan 26, 2009 | Panasonic NN-T888S Convection/Microwave...
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
114 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
