Question about SanDisk Sansa e270 MP3 Player
Refreshing Database ok, my sansa e270 is stuck in refreshing database screen. i've been having trouble with it for the past month,it's been frozen on a song it just wouldn't play, it wont be recognized by my computer, it keeps shutting off atfer i plug it in and get on "rhapsody" it will just go blank and restart. the only way i could get it off the frozrn song is to take out the battery. i really need help with this problem. any suggestions would be helpful.
  • 1 more comment
  • eric conrad
    eric conrad Feb 11, 2007
    I fixed my problem by consulting a SanDisk Technical Support agent on their website. This is what he sent me.
    "This issue may be due to some sort of corruption on the player itself. We should try formatting the player as a possible solution.
    First, please press the ?Power/Menu? button for about 20 seconds to soft reset your player.
    Caution: Formatting will erase all information on the Sansa mp3 player. Please be sure to have a back up of all the information before proceeding.
    Please note: The Sansa e200 mp3 series is supported ONLY on Windows XP as the MTP (Media Transfer Protocol) mode will function, only on Windows XP and it requires Windows Media Player version 10 in order to function properly.
    Also, MTP mode will not give you the FAT or FAT32 option. As soon as you select format, it will begin the operation, and format it accurately.
    Before formatting, please set your player to MSC (Mass Storage Class) mode.
    Setup Mode to MSC
    1) Tap your menu button and select "Settings" > "USB".
    2) On this screen, make sure that there is a check next to "MSC" and NOT "Auto Detect" or ?MTP?.
    To format the player on your PC, let us connect the e200 to your computer on an USB port preferably located near the power hub or to an external self powered USB hub, go to ?My Computer?, single right click on the ?Removable Disk? associated with your player, and select ?Format?. Let us please make sure that, under FILE SYSTEM, we change FAT to FAT32, and then single left click ?Start?. This will erase all data off the e200 and correct errors on it, which should make the e200 usable again.
    We also recommend formatting the player another way. Please be advised that formatting will erase all data.
    Please right click on my computer and select ?Manage?. When ?Computer Management? comes up, please click on ?Disk Management? on the left hand side. After clicking on ?Disk Management? you should now have a list of drives in the right side panel. On the right, look for the e200, it may show up as Disk 1, 2, 3? Removable Disk. Right click on the larger "Volume" rectangular icon to the right of the Removable disk and select ?Format? choosing FAT32. If you do not have the format option, please select "New Partition" and just keep clicking next through the Wizard that appears.
    After formatting the e200, please do try your player.
    If you have the standard e200, if applicable, please download the firmware update for your e200 from our website. The link is:
    http://www.sandisk.com/Retail/Default.as...
    If formatting and firmware update in your computer is not possible, please do try the process again on another Windows XP computer.
    NOTE: Please be aware that formatting is a normal and necessary method of drive maintenance and repair, and simply NOT formatting periodically can cause a drive to slip into failure due to the backup, and clutter of residual data.
    Please reply with the results.
    In order for us to complete your registration information please email back to us the "Date" and "Place of Purchase" of the device.
    Should you have any further inquiries or concerns, please do not hesitate to contact us via Email.
    Best regards,
    Anthony John Miles G.
    SanDisk Technical Support"
    Now if this doesn't work try this
    "This issue could have been caused by file corruption or system errors on the device.
    We should be able to fix your player. Disconnect the player from the computer if it is connected.
    Please copy and paste the following link into your web browser address bar, and then click Go or hit your Enter key. When prompted, choose the option to Save the file to your Desktop.
    http://www.sandisk.com/Assets/File/Downl...
    Once you have downloaded the file, please follow these instructions.
    1) Double click on My Computer so that you can see it on your screen.
    2) Turn the player off.
    3) On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see Orange.
    4) On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under "My Computer" called 16MB FORMAT. Once you see that icon you may release the Record button.
    5) Double click the file you downloaded earlier and run it. Follow all of the on-screen instructions, and when you get to the prompt where it asks you whether you would like to Format it, choose Yes. Once it is done, click Finish.
    6) Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
    7) Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
    Please advise.
    If it fails, kindly return the player from place of purchase, it is still under the 30 day return policy.
    Should you have any other concerns and queries please let us know, it is indeed our pleasure to assist you.
    Best regards,
    Now this is what worked for me, I hope this helps anyone else with the same problem I had.
  • Anonymous Jun 13, 2008
    i am having the exact same problem... except after i run the software, it cant find the version. please advise
  • JonnyStk Dec 30, 2008
    wow thank you so much!!! finally a remedy!
My sansa e200 not recognized in my PC and i can use for FM radio but only song can't showing in my ipod and even not showing menu it strucked it self showin "not enogh data base".
i need help with this problem, pls give me any suggestion
Posted on Jan 08, 2011
Works!
Posted on Oct 01, 2008
  • 3 Answers
Thanx you very much my mp3 now workin like an new viva fixYa ;)
Posted on Sep 27, 2008
I love you!! thanks this helped me :)
Posted on Nov 05, 2007
Sansa e270 freeze if switch on,it indicates,REFRESHING DATABASE"
Having gone over a month with no response, I assume the reset solved the problem.
Jul 08, 2010 | SanDisk Sansa e250 MP3 Player
My MP3 Sansa e200R froze while refreshing the database
Hold the menu button down for 15 seconds. This will reset the player
Mar 22, 2009 | SanDisk Sansa e260 MP3 Player
"Refresh Database" never ends!
If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
-Tha Mp3 Doctor
Mar 17, 2009 | SanDisk Sansa e250 MP3 Player
Frozen sansa at refresh database
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
Stuck on refresh/black screen
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 22, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e270 problem
You cannot - the firm upgrade delted them - you will have to refind them and redownload.
Jan 21, 2008 | SanDisk Sansa e270 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Sansa screen turns black after "refreshing database"
how about updating the firmware?
OOOOHHHHH
now we are getting somewhere
( how could someone not figure that out.... ha ha ha)
Dec 20, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e200r
my Sansa M200 has a frozen screen, tried removing battery but comes back screen frozen
Jan 04, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
249 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
