Question about Refrigerators
The coils inside the freezer behind the panel keep freezing solid. i have removed the panel and let them totaly defrost. is there something that needs to be reset to keep this from reacuring. ive defrost them then they freeze up again about two to three days later
  • 306 Answers
There is a defrost timer located inside your frig. When you open the door you will see a small housing on the top now look for a opening that has a screw driver flat blade looking switch. Take a flat screw driver and turn until you hear a click. That should be defrost cycle now wait 30 minutes and take note of the position of the screw you had moved earlier. If it has not moved the timer is bad and will need to be replaced. This is a old trick we do in the field to move into defrost and see if it was stuck or needs to be replaced. More then likely will need a new defrost timer. let me know how it all turns out. ken
Posted on Dec 02, 2008
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
Aug 05, 2010 | Whirlpool Refrigerators
My refrigerator model # JTB2188AEA the bottom half dosent get cold enough and the top half get cold but dosent freeze
your evaporator coil in the freezer behind a panel has iced over and the fabn can't move air over a solid sheet of ice,remove the panel,defrost it with a hair dryer,then check the defrost heating element and defrost thermostat under the coil and defrost control in the refrige section for proper operation
Jul 28, 2010 | Jenn-Air Refrigerators
Water leaks from top mounted freezer area into the refrigerator
Remove the food from the freezer and the icemaker if equiped . Remove the air tower at the rear of the freezer section and remove the rear panel inside the freezer . Using a hair dryer to the drip pan , below the coils ( probably ice ) , starting at the center , defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water starts to flow down . Using a short piece of hose , insert it into the drain hole and blow . This should blow out any debris inside the drain hole . I would use a short piece of solid ALUMINUM wire ( 14-16 guage about 8 " long ) striped of all insulation , and insert it into the hole as far as possible , without any force . Wrap the other end about 1--1 1/2 turns around the black tube ( defrost heater ) above the hole . When the heater comes on , heat will transfer to the aluminum wire and keep the drain from freezing up again . Reasemble back panel , air tower , and , icemaker . Reinstall the food and its FIXYA'd .
Sep 02, 2009 | Refrigerators
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
Freezer back panel freezes up
hi thanks for the question the problem you have is with either the defrost termination switch or the timer the defrost termination switch is located in freezer a small disc with 2 wires going to it replace this part thanks the appliance doc
Aug 14, 2008 | Frigidaire FRS23KF7AB Side by Side...
Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Aug 12, 2008 | Samsung RS2630SH Side by Side Refrigerator
Defrost Drain in Freezer is Freezing Shut
it totaly needs to be defrosted with the doors open for a couple days. the drain tube might be pluged with something else than ice. once defrosted poor some water down the drain to make sure its unpluged. dont for get to empty the pan!!!
Jan 16, 2008 | KitchenAid KTRC22EL Top Freezer...
Solid ice behind freezer panel door
your refrigerator has something wrong in the def system. the most common problem is the def thermostat.
Dec 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
