Question about Malber P21 Front Load Washer
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
Hi, My Malber P21 washer is 7 yrs old, and has been working perfectly until a week ago. Now whenever it washes (on any cycle), it takes 3 times longer than usual, it sounds like it is pausing and stopping and "thinking" of what to do next. What can be the problem? I have never had the machine serviced before.
  • tjk2001 Jan 31, 2009
    We have the same problem with out Malber P21, which is about the same age as Yaelita's. The machine takes much longer to get through each cycle, but the total time varies, and it seems to stop and "think" at different, unpredictable points in the cycle, so that it doesn't seem to be a problem with a particular transition.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Posted on Jan 17, 2009
I have a Malber P21 washer on board a boat and it will not spin out the water. It is spinning but the water remains in the tub
Posted on Feb 19, 2009
My washer skips the last spin drain? It ticks from 5 to STOP very quickly and clothes are still dripping wet.
Time to replace your timer sounds like you have a mechanical timer not too difficult to do.Work safe.
Dec 03, 2014 | Malber P21 Front Load Washer
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
http://www.ajmadison.com/cgi-bin/ajmadison/P21.html
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email INFO@MALBERAPPLIANCE.COM.
Oct 17, 2014 | Malber P21 Front Load Washer
My malber washing machine p21 will not turn on it is making a clicking sound but nothing else
It might be due to the switch problem or wire will be cutted for that which runs the engine... Check the wiring and switch on the machine..
Thanks
Apr 01, 2012 | Malber P21 Front Load Washer
I NEED A NEW HOSE " Y - INTO ONE. WHERE CAN A GET ONE? I HAVE A MALBER P21.
I'm a general contractor. I made up a new hose by using various couplings
and a speedy connector.
Jun 25, 2009 | Malber P21 Front Load Washer
Malber Dryer won't start (sine-wave light flashing)
The dryer is easy: turn it on and turn the control to 0. It will beep. Then turn it to the desired program (20, 40, 60 minutes or a pre-programmed cycle), it will beep again and start. If there's a red light you have to empty the water tank at the front on the left. The washer is a normal washer. Just pick your program and press start (be patient as it takes a while to get cranking). Sometimes you have to really push the door closed very hard. Try and turn the control to 12 o'clock before setting it again.
May 30, 2009 | Malber TD800 Electric Dryer
Malber P21 - works slower and slower
hi from uk from what you describe /symptoms this is sure to be the motor brushes are worne very low and req renewing this is not beyond the d i y novice and the 2 x brushes for the motor here in uk cost approx £5 and easy job to renew if you remove rear panel off machine then remove motor you will see how it looks and secures just like a car alternator and also belt adjustment is same the brushes will be self explanitary of how they are renewed once motor is removed ? hope this helps/inspires you and will save you $$$$s by diy
Dec 02, 2008 | Malber P21 Front Load Washer
Water leaks from bottom
IT SOUNDS LIKE YOU HAVE A BAD POINT IN THE TIMER,YOU CAN TAKE IT OUT TO SEE IF BURNT OR WORN,ALSO YOU CAN LEAVE PLUGGED IN AND WITH A PIECE OF PLASTIC NOT METAL PULL DOWN ON EACH POINT TILL YOU FIND THE BAD ONE,THANKS-MIKE
May 29, 2008 | Malber P21 Front Load Washer
Malber P21 won't empty...
noif water is gussing out when u puy the drain hose low to the ground then your pump has gone a way to check this without any water in the tank take of your outlet hose u will see a little fan inside the pump put it on empty get a screw driver and carefully place on the fan if the fan stops then it definetley neds replacing sorry love all u can do
Aug 22, 2007 | Malber P21 Front Load Washer
My washing machine won't fill with water
I have my washer connected to the kitchen sink. In order for it to fill I have to connect the hose to the faucet and turn it on, it is pain but that is the only way it will work for me. I hope this helps.
Sep 15, 2006 | Malber P21 Front Load Washer
Malber P21 Front Load Washer Logo
280 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
