Question about HP Officejet 6310 All-In-One InkJet Printer
Printer is printing twopages per sheet ( HP 6310)
My printer started printing 2 pages per sheet and shrinking it all down to fit
    Novelist:
  • 88 Answers
The HP All-In-One printers have a PREFERENCES/PROPERTIES option called "Pages Per Sheet" that controls this behavior. If it was changed by someone, you can set the default by right-clicking on the printer from the PRINTERS window and selecting PROPERTIES. Then click on PRINTING PROPERTIES from the GENERAL tab and set "Pages Per Sheet" to 1.
If this helps, I would appreciate the feedback.
Thanks!
Posted on Dec 02, 2008
Bottom portion of lines of text fails to print (using HP 6310). Occurs randomly from top to bottom. May happen only once on a page and then sometimes it may be 2-3 times per page as you go down a page of...
olson5829,
Your ink cartridge is about empty or some of the head nozzles are plugging up randomly. Click on "start", mouse over settings which should show several selections, click on "printers and faxes". Right click on the printer icon and click on "properties". In the next window you should be able to select clean cartridge under one of the tabs. Do a cleaning and see if it works better. If this does not solve your problem you need to purchase a new cartridge. Now that cartridges are recycled this type of print problem happens more often.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 17, 2011 | HP Officejet 6310 All-In-One InkJet...
Hello My HP OfficeJet 6310 all in one has problems. When I print documents come out with a small amt of content on many many sheets. For example a fully page of text to print comes out on about 8 pages...
This is due to buffer memory is having the issue. Repair/replace the same with the help of expert engineers or service center experts.
Thank you for using Fixya.
Jul 22, 2010 | HP Officejet 6310 All-In-One InkJet...
My printer has started printing with a tiny font that is barely readable. I can't find any size adjustments in the properties prior to printing. So I'm stuck with the tiny print. Don't know what...
Click Start > Printers & Faxes > Right click on the Printer's icon > Printing Preferences > click Feature tab > look at the "Two sided printing" > and set if "off" > Apply"
Again on the Feature tab look at the "pages per sheet" and set it to "1 page per sheet" (if it's not set to) > Apply, again click on the "Advanced" tab and turn off the "Mirror Image" > Apply
You also need to check the printing preference when you give the print command from the document, When the print windows is opened, check "page scaling" "page arrange" and "page rotate" and set them to "fit to page/actual size", "none" and "normal" respectively. This will fix your problem and you'll get the normal prints.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | HP PSC 2410 All-In-One InkJet Printer
How to print 2pages on one sheet of paper (side by
press key with windows logo(bottom of keyboard, both sides of spacebar),choice printers and faxes,find printer your using(if you have more than one listed, or the one with check by it),double click, when document box opens,click on printer(upper left at top of box),under page layout choose # of pages per sheet...2 will give you 2 pages side by side,4 will split the sheet into 4 quarters.
Mar 20, 2010 | HP Officejet Pro L7680 All-In-One Printer
Can I print double sided documents with a hp 6310 all in one?
I don't see multiplexing as an option for your printer.
The manual way to do this though is to go through your regular print procedure but choose the option to print only the odd numbered pages and then simply put the printed pages back into the printer tray upside down (after giving them some time to dry) and then print only the even numbered pages.
Feb 22, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
My printer (HP 6310) started printing two pages per sheet in Landscape mode and shrinking it down. There must be a setting or something but I can't find it
Thanks!
Dec 02, 2008 | HP Officejet 6310 All-In-One InkJet...
HP 6310
It seems it does not like the driver. Did you install it from the installation CD provided? If not try this & see what happens.
Sep 15, 2008 | HP Officejet 6310 All-In-One InkJet...
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
81 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
