Question about HP Officejet 6310 All-In-One InkJet Printer
My printer (HP 6310) started printing two pages per sheet in Landscape mode and shrinking it down. There must be a setting or something but I can't find it
    Novelist:
  • 86 Answers
The HP All-In-One printers have a PREFERENCES/PROPERTIES option called "Pages Per Sheet" that controls this behavior. If it was changed by someone, you can set the default by right-clicking on the printer from the PRINTERS window and selecting PROPERTIES. Then click on PRINTING PROPERTIES from the GENERAL tab and set "Pages Per Sheet" to 1.
If this helps, I would appreciate the feedback.
Thanks!
Posted on Dec 02, 2008
6310 problems
You have not really provided enough information to properly answer your query. However, a couple of things to check. Did you set the right page size when printing? Was the size of the item being printed able to fit on the paper size chosen? Finally, did you ensure the page format was correct - eg: as in a landscape shaped original on to perhaps a portrait shaped paper?
Jul 27, 2014 | HP Officejet 6310 All-In-One InkJet...
Bottom portion of lines of text fails to print (using HP 6310). Occurs randomly from top to bottom. May happen only once on a page and then sometimes it may be 2-3 times per page as you go down a page of...
olson5829,
Your ink cartridge is about empty or some of the head nozzles are plugging up randomly. Click on "start", mouse over settings which should show several selections, click on "printers and faxes". Right click on the printer icon and click on "properties". In the next window you should be able to select clean cartridge under one of the tabs. Do a cleaning and see if it works better. If this does not solve your problem you need to purchase a new cartridge. Now that cartridges are recycled this type of print problem happens more often.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 17, 2011 | HP Officejet 6310 All-In-One InkJet...
My HP PSC 1200 printer has started printing all landscape documents as portraits and visa versa. Reinstalling has not helped.
hi
goto the control panel-->printers and faxes and do a right click on the printer icon.now goto printing preferences and change the settings as per your need
there is also a check box for showing the preview before printing,check that ,now everytime you want to print something it will show you a preview in advance for how the print out's gonna look like
you can change the settings as portrait or landscape by going to printing preferences.
hope this helps
Jul 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printing long sheets (1188 mm lengt) with Epson Stylus 1520
Set custom page setup at printer setup. Set as landscape. Print landscape.
Jun 12, 2009 | Epson Stylus 1520 InkJet Color Printer
Can I print double sided documents with a hp 6310 all in one?
I don't see multiplexing as an option for your printer.
The manual way to do this though is to go through your regular print procedure but choose the option to print only the odd numbered pages and then simply put the printed pages back into the printer tray upside down (after giving them some time to dry) and then print only the even numbered pages.
Feb 22, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer is printing twopages per sheet ( HP 6310)
Thanks!
Dec 02, 2008 | HP Officejet 6310 All-In-One InkJet...
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
Can't print landscape?
Make sure the correct printer driver is installed.Check your user guide.Read the information below.
Printer Settings
You can use the printer properties window, which allows you to
access all of the printer options you need when using your
printer. When the printer properties are displayed, you can
review and change the settings needed for your print job.
Your printer properties window may differ, depending on your
operating system. This Software User’s Guide shows the
Properties window for Windows 98.
Your printer driver Properties window that appears in this User’s
Guide may differ depending on the printer in use.
If you access printer properties through the Printers folder, you
can view additional Windows-based tabs (refer to your
Windows User’s Guide) and the Printer tab (see “Printer Tab” on
page 10).
NOTES:
• Most Windows applications will override settings you specify
in the printer driver. Change all print settings available in the
software application first, and change any remaining settings
using the printer driver.
• The settings you change remain in effect only while you are
using the current program. To make your changes
permanent, make them in the Printers folder.
• The following procedure is for Windows XP. For other
Windows OS, refer to the corresponding Windows User's
Guide or online help.
1. Click the Windows Start button.
2. Select Printers and Faxes.
3. Select your printer driver icon.
4. Right-click on the printer driver icon and select
Printing Preferences.
5. Change the settings on each tab, click OK.
Layout Tab
The Layout tab provides options to adjust how the document
appears on the printed page. The Layout Options includes
Multiple Pages per Side and Poster. See “Printing a
Document” on page 6 for more information on accessing printer
properties.
Orientation
Orientation allows you to select the direction in which
information is printed on a page.
• Portrait prints across the width of the page, letter style.
• Landscape prints across the length of the page, spreadsheet
style.
• Rotate allows you to rotate the page the selected degrees.
Layout Options
Layout Options allows you to select advanced printing options.
You can choose Multiple Pages per Side and Poster.
• For details, see “Printing Multiple Pages on One Sheet of Paper
(N-Up Printing)” on page 12.
• For details, see “Printing Posters” on page 13
Jan 16, 2008 | Samsung ML 2010 Laser Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
62 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
