Question about T-Mobile Dash Smartphone
Tmobile dash won't get out of alarms screen
Bought this phone from ebay and when i power it on, everything goes on ok, but then a bunch of alarms start going off, and i can't get out of that screen
  • 87 Answers
You need to reset it (small button on back or inside battery cover) and if that doesn't work then you need to do a hard reset by opening the battery cover, taking out the batteries and pushing the reset button on the inside.  unfortunately the hard reset will delete everything.... but it will fix the problem
Posted on Dec 02, 2008
Where is the OUTBOX on a TMOBILE DASH
when your in the messages screen go to menu and click on folders and that brings it up. Hope that helps.
Apr 12, 2009 | T-Mobile Dash Smartphone
My tmobile dash freezes every time i try to start.
Turn the handheld off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
How to Hard Reset a T-Mobile Dash with operating system: 1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
if this helps please rate the posting..thanks
Mar 02, 2009 | Cell Phones
Unlocking Sidekick ID purchased from ebay
try turning it on and typing 1234 it should work it worked for me and if that doesnt work try goin to a cell phone repair shop they should be able to unlock it. if not get your money back for the phone and buy one at the tmobile store. some stuff on ebay doesnt work i bought an ipod off ebay and it broke the next day it broke so try gettin your money back if nutin else works!
Jul 22, 2008 | T-Mobile Sidekick ID Cellular Phone
Passkey
Good Day,
Passcode is "0000"
Hope this helps
Jul 05, 2008 | Radio Communications
Dash stuck on opening TMobile screen
The Windows Mobile installation may be corrupted.
The only way to fix that problem is by re-installing the windows software on the phone.
You can get the software for the T-mobile dash at the following link: http://www.t-mobile.com/wmupgrade/
Be warned that if you use this method most of the data on the phone will be lost, like text messages and etc. Your contacts should be fine as the are stored on the SIM Card and if you have been syncing your contacts with your PC then they should get loaded when you do the up
Jul 04, 2008 | T-Mobile Dash Smartphone
T-mobile dash
I tried using a the google mail java app on my tmobile dash. It froze up on me, and when i turned it back on it just stays at the "tmobile" splash screen. I have tried using the soft key and power button reset but it doesnt work. What's weird is that it wont power down unless I take the battery out. It powers on, shows the tmobile splash screen, then freezes. Is there any other way to reset it or is it totally bricked? I bought it new off craiglslist so tmobile wont replace it for me cause I'm using it unlocked on cingular.
Ok bro I know I am a bit too late to help you with this problem but someone else may benefit from these directions. I see most places online only have half advice about this very common problem with T-mobile Dash.
This is what you need to do, you have to do a hard reset exactly like "reviel" mention. Also like he said timing is essential but the trick is that you need to show some patience through the process.
Note: Please read the directions completely before doing anything for better results.
Step 1: Take your battery out and shut off your phone
Step 2: Press and hold the two soft key buttons.
Step 3: Press and hold the power button for exact two seconds, 1001, 1002 and release, but continue to hold the two soft key buttons.
Step 4: Within seconds a black screen with some text will come up asking you to confirm if you wanna delete everything; and right then you let go of your soft key buttons and press the green call button (also known as the "send key").
Step 5: You are done but not really, your job now is to find something else to do and leave your phone alone for at least 2 minutes. Eventually if you don't have a SIM in it, it will prompt you for it and you click the soft key to choose "OK"; also, it will ask you to confirm to restart and you click the soft key to chose "Done" for it.
Wait a minute for it boot up and overall it should do it.
May 31, 2008 | T-Mobile Dash Smartphone
Won't Boot Up, Alternates between Windows screen and TMobile screen
Master repoot the phone. You will loose all data, but you can recover the phone.
1. PRESS AND HOLD BOTH SOFT KEYS.
2. WHILE HOLDING DOWN SOFT KEYS, PRESS AND RELEASE THE POWER BUTTON, WAIT 3-5 SEC. (PHONE SHOULD POWER ITSELF ON BY DOING THIS)
3. RELEASE THE TWO KEYS SOFT KEYS.
4. WHEN SCREEN ON DASH LOOKS LIKE IT'S IN DOS FORMAT, PRESS SEND (GREEN ANSWER KEY)
May 16, 2008 | T-Mobile Dash Smartphone
Cracked Tmobile Wing Screen
My Wing LCD has cracked twice. The problem is in the design, and T-Mobile will need to fess up.
Feb 07, 2008 | T-Mobile Wing™ Smartphone
TMobile Sidekick 2
yep, you can do a master reset.
Want to clear out info on your Sidekick info (ie: to sell yours)?
1) Remove your sim card
2) From the jump screen: Menu -> Settings -> System Info
3) Press Menu+Shift+X Select OK to clear the flash.
4) Press Menu+Shift+R Select OK to clear the login information.
5) Perform a hard reset now. This will reboot the device.
To perform a hard reset:
SK2 - Press the power button and reset button at the same time. Unit will vibrate when reset. You can use a paper clip or similiar to hit the reset button located behind the screen.
6) Call your carrier and ask them to detach your device IMEI from the username locked in. Once that is done, hard reset without your SIM card inserted.
You're done.
Jan 01, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Hard-reset on tmobile dash
nope....sorry. once that info is gone, its gone.....unless you backed up the info on your computer manually previously
Nov 15, 2007 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
51 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
