Question about Breadman Kitchen Appliances - Others
Kneading blade stays in bread after cooking.
After removing the bread from the pan the kneading blade cooks in bread loaf. I have to tear a hole in bottom of loaf to remove it.
  • gunn94954 Dec 02, 2008
    Hi Alleillia ,
    I've tried both of your suggesti0ns and it still cooks in the bread. It's an old bread maker and I guess the kneading blade is too loose. I appreciate your help. Thank you for trying.. Beverly
  • 69 Answers
This sometimes happens. I have a Panasonic.
When you place contents in pan with some machines it is important to place contents
in a particular order. I should try to keep contents away from the kneading blade as you place them.
Another thing that might possibly help is to put a litter olive oil around the blade before adding ingredients.
Hope that this helps
Alleillia
Posted on Dec 02, 2008
Kneading paddle bakes into the bread
Kneading paddle on EVERY breadmaker usually bakes into bread. Let the loaf cool and then gently remove it. Or use the dough setting and cook bread in the oven. (i do this) delicious!
Jul 05, 2017 | The Kitchen Appliances - Others
I have a Sunbeam Convection Bakehouse model BM005 and the bread pan sticks all the time so badly that is it impossible to get the loaf out without mutilating it. What can I do?
We have one and used it for years. What we found works is to take the kneading plate out before it starts cooking. Do this after the beeps to let you know when to add fruit, and the kneading has finished.
This also saves bread as you do not loose a bug chunk in the bottom. Our pan is not very good any more, but we can still get the loaf out without any problems. Just need to let it cool for about 10 minutes out of the machine before attempting to take the loaf out if it is stuck.
Nov 24, 2010 | Sunbeam Kitchen Appliances - Others
Crust is thick and hard, paddles tear large chunk from bottom of loaf when removed from pan.
unfortunately all bread machines leave the hole in the bottom where the paddle is. some machines leave a bigger hole than others, with the exception of the cuisinart cbk-200 which allows you to remove the dough, then remove the paddle, then reshape and replace the dough....One thing you can try to have a softer, lighter crust is to replace the water in your recipe with the same amount of milk. If the hole in the big hole in the loaf really bothers you I suppose you could remove the dough exactly at the end of the final knead, remove the paddle and replace the dough in the pan...I've never done it but I've certainly considered it! best wishes and happy breadmaking...
Nov 08, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Kneading paddle is baked into bottom of bread loaf. Is this normal?
Yes, this is a common occurrence.
Nothing to worry about unless you chow down and forget to remove the paddle(s). :)
Since the paddle(s) stays in the pan after the kneading and through the baking process. The bread can trap the paddle(s) as the batter cooks.
We have gone through 3 different bread machines and over time all eventually did this. A little wear on the spindle will loosen the paddle(s).
Hope this helps!
Dec 26, 2009 | Sunbeam 5833 ExpressBake Bread Maker
I love my bread machine, model 5890, but with every loaf of bread the kneading blade stays inside the bread. The bread is also difficult to take out of the pan. This has led to scratches in the pan as...
I usually take the paddle out of the machine at the end of the kneading cycle and before the rise cycle. (Do this with the pan out of the machine..just in case). You don't want to use anything in the pan that will scratch it. Usually a few quick taps of the bread pan on the cutting board will free the bread.
Dec 05, 2009 | Sunbeam 5890 ExpressBake Bread Maker
BREAD OVERBAKES
Take a look at your manual. There are a couple pages with charts showing the kneading and bake times for the machine. Try setting a cycle for a smaller loaf. I have a similar problem and had been setting a timer to take my loaf out early.
Apr 10, 2009 | Breadman TR444 Bread Maker
Kneading blade cooks into the loaf
Hi Jessica,
As I read the manual, under the Care & Cleaning section,
"2. If the kneading blades remain in the bread pan, grip the kneading blade and
pull straight up to remove......"
Based on the diagrams and instructions, I don't think you're supposed to pull the blades before baking...why do you want them out? Cosmetics?
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Jan 08, 2009 | Black & Decker B2300 Bread Machine
Kneading blade stays in the bread
I had that problem with my Zoji breadmaker. I sprayed a little non-stick spray on the blad and it worked. You can also spray the pan.
Jan 06, 2009 | Sunbeam 5890 ExpressBake Bread Maker
Kneading blade won't come out with the bread
one thing that i do is i lube the shaft with cooking oil and that seems to work getting the paddle out but for nor not tearing the bread you have to remember that it is baked into it
Oct 03, 2008 | Breadman TR520 Bread Maker
Replace kneading blade
Go to e bay. They have a couple of stores that sell nothing but parts for bread machines.
May 08, 2008 | Cook's Essentials Dual 1LB Bread Maker
Kitchen Appliances - Others Logo
449 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
paul
paul
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
