Question about Primera Technology Bravo (Refurbished) (62701R) CD-R Burner
My maytag bravo top loader washer is displaying a code of LF and
My Maytag bravo top loader is displaying a code of LF and stopped, can you tell me what that means?
  • Anonymous Mar 21, 2009
    Our Maytag Bravo is displaying the code LF on ever single cycle. What's wrong?
It meant "low flow" check water connecting lines. mine has the same problem.
Posted on May 10, 2009
Maytag washer bravo that water filling up too slow, code lf shows
Water valve stopped up. Check screens in the valve and hoses if present in hoses.
Aug 28, 2017 | Maytag Washing Machines
I can not open the door on my Maytag top loading washer
Many new washer use a lid lock instead of a brake to keep people from reaching into the spinner before it stops. You probably have a
bad lid lock. Have a repair man open the top cover and repair or replace the lid lock.
Jul 06, 2016 | Maytag Washing Machines
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
LF appears after my maytag front loader is washing for about 4 min. We took the screens out, cleaned out and swapped ends of hoses from washer to the water valves. Still not working. Washer only a yea
LF means long fill....if the flow meter does not detect
the correct amount of water entering the machine the
code will appear. Google Maytag front load washer
LF code...there are several links including a video
that should help you solve the problem.
Regards,
Dennis
Oct 05, 2014 | Maytag Washing Machines
What does LF mean on the washer? When I start my load it pops up as LF and stops washing. What do I need to do or what is wrong?
LF (F30)
LF flashes when the control don't sense any water coming in like it is supposed to do. Things to check:
Hoses connected; water turned wide open.
Is water siphoning out due to having the drain hose too low? (30 inches above the floor)
Pressure hose from tub to control loose, pinched, hole, Sediment in tub? themobilian_1135.jpgthemobilian_1136.jpgBlow that tubing out and re-secure; retry with water OUT of tub so the pressure can properly build in that tubing. themobilian_1137.jpg
Bravos codes and service manual HERE
Jan 29, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
I have a Maytag Bravo top load glass washer and a f51 code. Top wont open and machine has stopped
Defective hall sensor most likely, The cabrio bravos and Oasis machines are all basically the same.
MORE here
Dec 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
I have a new Maytag Bravo top loader.
That means low flow. Turn up water valve. If that don't work then shut your water off take off hoses and clean the screens on the washer they are dirty that happens with hardwater
Apr 29, 2010 | Maytag Bravos 4.5 Cu. Ft. Washer
I have a maytag bravos and i keep getting LF WHAT Dose that mean
(Washer is taking too long to fill)
Check the following:
Are the hot and cold faucets turned on?
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press POWER/CANCEL to clear display.
Hope this helps.........................
Oct 03, 2009 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos top load gives LF code..not working ... any idea?
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
Jul 18, 2009 | Maytag Bravos MTW6600T Top Load Washer
Primera Technology Bravo (Refurbished) (62701R) CD-R Burner Logo
713 people viewed this question
Top Primera Technology Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
ray gallant
Terry Hair
Are you a Primera Technology Computer and Internet Expert? Answer questions, earn points and help others
