Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Power comes on then goes back off.
I have a Panasonic PT-53WX53G projection television. I have just recently had problems with this TV. You can turn the power on with either the remote or the button on the TV. After about 5 sec. the TV turns off and the red power LED blinks three times. The service manual says that the TV is in self-diagnosis mode. The manual also says that the LED blinking three times means that their is a convergence problem. Now in order to fix the convergence you need to have the television in service mode right? Could this be a convergence problem or is it the convergence circuit?
  • 4 more comments
  • Anonymous Nov 14, 2007
    tv comes on for a moment and then back off. worked fine night before.
  • Anonymous Dec 13, 2007
    My problem is exactly as described above by the first two posts. Worked fine night before - no sign of pending problem. Just won't come on anymore. Try turning it on and the red light blinks. Unplug from wall and let set for a while, plug back in, hit power and TV comes on briefly then shuts down - blinking red light again!
  • BrentDev Dec 16, 2007
    Exact same problem.....and there was a burning smell when it popped (like a card had fried).
    Still comes on briefly, then off, red light blinking.
    So - if I pull the rear access cover, is the card I am looking for "obvious?" I know I can go look for a smoked component. Are the Convergence Chips easy to spot?
  • yrrepynot Dec 23, 2007
    Tv comes on then goes off. LCD light blinks
  • Anonymous Jan 19, 2008
    The same problem as the others. Turn on the TV and basically the red light on the front of the system blinks.
  • boneseller1 Nov 12, 2008
    Problem is as described by others. T.V. turns itself off with red blinking light in front. after unpluging unit and turning it on again it will come on for a second or two then shut off again.
A tech wants to charge $89 just to troubleshoot. So how much will convergence cost?
Posted on Dec 15, 2007
    Sergeant:
  • 308 Answers
More than likely, the two convergence IC's have to be replaced.
Posted on Jan 30, 2007
MY PT-53WX53G turns off when powered on. The
Thats the error for convergence failure. Heres a link to the repair kit for your model which contains the parts and the CD with detailed instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Jul 06, 2010 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Black screen
how many times does the red light flash?
Techman
May 16, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Jun 19, 2009 | Panasonic PT-53WX53 53" Rear Projection...
3D image on panasonic 53''
Sounds like the red and green images have shifted.
In your settings menu there should be an option for it to self adjust or manual adjust of the red and green images alignment.
Apr 02, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53wx53G 53' projection tv problem
was your tv hit hard,a non magnetically shielded speaker set on top or under it?
Nov 09, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt-53wx53g tries to turn on but goes right off
That is indicating that the convergence circuits have shutdown the set. You will need new Convergence ICs. They should be STK392-110 or STK392-120 either number works the 120 being the better chip. I will post a link where you can get the new ICs and they provide step by step instructions with pics so you can do the repair yourself. You will find your IC numbers under the section titled Convergence ICs just click on that and you will find your STK numbers.
Mar 30, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Removing D board
You can get the entire service manual emailed to you at the following link. It cost 10.99 and comes with unlimited free support to help you with your diagnosis your problem.
Feb 19, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
160 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
