Question about Kenmore 43042 Front Load Washer
Kenmore 43042 front load banging during spin cycle
My front load washer recently starting banging during the spin cycle like it's going to tear itself apart. I took the top and back off and I can find no problem with anything in the unit. The bearings and pulley/belt all seem to be fine with no noise or rough spots. I have seen some prior similar posts and it appears that some people are replacing the complete inner and outer drum units to solve the problem. Prior to spending another 1/2 of what the washer cost was originally I was hoping this might be a common problem with a more simple solution? Does anyone know if there is an easier/cheaper fix for this problem?
  • 2 more comments
  • ExpressDeliv Dec 08, 2008
    My Kenmore 43042 made a loud noise and shook then stopped working. It's less than 4 years old. I called Sears/Kenmore and they offered to do nothing although are well aware of the defective design of this machine.
    I won't be buying Sears again.
  • lshagoury Dec 09, 2008
    I have the same problem. The washer is less than 3 years old.
  • Anonymous Dec 10, 2008
    • the problem is the rear outer tub has bearings and more than likely its thebearing towards the front of the machine, i took my washer apart knocked the bearings out, went to a auto store, matched the new bearings to the old and replaced them, it took awhile to do the job, but it only cost me 20 dollars, compared to the 700.00 sears wanted.
  • fobage Dec 28, 2008
    I have the same problem but I also have a big leak that occurs while filling. The bearing going out would it also cause a gap that would also cause a leak? The control board has got wet and blown for the third time in 4 years is theie anyone that can rebuild. They are almost $200.00 a board.
osborne382
  • 306 Answers
SOURCE: Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Posted on Dec 11, 2007
SOURCE: kenmore 44832200 banging during spin cycle
YOU MIGHT WANT TO TGRY TO PAY ATTENTION WHEN YOU LOAD THE CLOTHES IN. TRY TO LAYER THEM LIKE A CAKE AND NOT JUST TROW THEM IN. I HAD THE SAME PROBLEM
Posted on Jan 11, 2008
  • 26 Answers
SOURCE: bearing noise
You have to remove the outer tub assy from the cabinet then split the halfs, We're told the the bearings are part of the rear tub housing. You might be able to press out the bearings
Posted on Feb 12, 2008
  • 6 Answers
SOURCE: Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Posted on Feb 13, 2008
Coldcut
  • 1554 Answers
SOURCE: frigidaire crtr9300
from the top access ,
check the suspension out like you would a car,
move the drum up and down and sideways ,
it should resist and settle w/o bounce,
the springs should be tight.
the placement of the marks will give you an indication as to which opposite arm or spring is weak.
Posted on Jun 13, 2008
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
My Kenmore Front Loader washer machine is making a loud noise during the spin cycle
tub bearing more than likely.tub has a 10 yr warranty so call sears get the flat rate labor charge their offering then have them replace the tub
Jan 11, 2010 | Kenmore 43042 Front Load Washer
Horrific banging when in the spin cycle
There are a series of balancing springs connected to the drum. It sounds as though one of them has come off or loosened. Yuo'll need to turn the machine on its side to find out. Good Luck! Let me know how you make out.
Jun 08, 2009 | Kenmore 43042 Front Load Washer
Noise during spin cycle
I Can help
1: Unplug the Washer, turn off hot cold supply to Hoses.
2: Turn Washer around and remove Cover on Back.
3: Look at the "Belt" pull on it to see if it is Loose.
4: Check the "Pulleys" The "Belt" is connected to. Look for Signs of "Blackness" Caused by the Belt Wearing.
5: If thats the case just Replace the Belt.
Hope it helped
Please Rate Me
George
Apr 28, 2009 | Kenmore 43042 Front Load Washer
Kenmore front load washer 417-44082400
My kenmore front load did that just a few months after I bought it. Unfortunately it was the the electronic board {brains of cycles} that had to be replaced. Had to replace it 3 times!! Warranty did cover it. Look into your warranty--at that time the boards were $200-$250 each!!
May 13, 2008 | Kenmore 43042 Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Washing machine is louder then normal on the spin cycle.
This sounds like the rear bearing is going. After getting louder, the next problem is grease appearing on your clothes during the spin cycle. This is a very major repair.
Jan 10, 2008 | Kenmore 43042 Front Load Washer
Kenmore 44832200 banging during spin cycle
The support spring beside the spinning hausing are cut replace w/new spring available appliances store. bring sample.
Jan 07, 2008 | Kenmore 44832 Front Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Kenmore 43042 Front Load Washer Logo
227 people viewed this question
Sal De
fordexpert
Robert Rankin
