Question about Wahl 8550
Took unit apart to clean and need reassembly diagram please
Model 8550 -
I have two brackets, thick grooved blade and under blade and cannot remember how it goes back together.
  • 3 Answers
The thick racket sit on top of the lil gold bracket
Posted on Jun 20, 2009
Hi I took apart my oven door on my atwood Wedgwood to clean in between the glass and now can't figure out how the two black brackets go on. I took them off the inside bottom to take off the glass
To help you, I need the model number for your unit--try to locate the exploded parts diagram(type in your model number and then type "parts" without the quotes) online or call the manufacturer--some user manuals have a parts breakdown
Aug 23, 2015 | Ovens
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
How to reassemble blades on Wahl rechargeable unit
I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
1. the bottom part has a little "nub" that the screws attach to
2. the second part is the thin piece of metal with a ridge
3. the white plastic thing, make sure the ridges are sandwiched together
4. the small blade, the blades must face each other
5. the large blade
use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
It's STUPID that this is missing from the instruction guide that comes with the clippers.
Mar 15, 2010 | Wahl 8550
Why does my hp color laserjet 8500 drum keep getting streaks on it? I clean it and streaks slowly appear....
clean under the flaps of it with a ear bud or something , there must be some dust or something inside of it. hope this helps in some way.
Dec 03, 2009 | HP LaserJet 8500 Color Printer
How to reassemble my wahl clipper model 8081
Okay, if you took this machine apart don't worry. You would have noticed when you loosened the first two screws closest to the blade (but still on the body of the trimmer) a small white part of the trimmer flew out...you were probably think wtf? Yeah, okay. If you took all four screws out, make sure you align the cord within its allocated space on the frame and screw in the bottom two.
1. Now, leave the top two screws about 75% loose so that you can slip the white piece back.
2. You will notice that there are two prongs sticking out of the hole where the blade is suppose to go. Make sure the "Detailer" enscribed on the front of the trimmer is facing the ground (or opposite yourself). Align the white piece so that the groves are facing the prongs and the other half of the white piece is facing yourself.
3. Slide the white piece down as far as reasonable, without forcing it. There is a little hook on the white piece, and a corresponding groove on the casing of the Detailer. Make sure that you align the white part so that the hook aligns with the groove, also make sure that you have aligned the groove on the back side of the white piece with the small round tip of the motor.
4. Okay, so this is the tricky part, you will probably be saying...the white piece is still sticking out. Well this is initally why it flew off when you took the machine apart. The blade acts a spring load for the white piece and the top two screws on the casing holds the remaing pressure forced on the white piece. What you need to do now is align the blade and its screws with the corresponding holes on the maroone casing and push the front of the blade down on the white piece and tighten the screws. The machine should now be working.
Hope this helps.
Oct 18, 2009 | Wahl 8081
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Aug 13, 2009 | Andis Health & Beauty
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
May 20, 2009 | Conair GMT200TD
Wahl 8550 Pet Clippers Won't Work
Tried the above solutions but it all keeps falling apart. It's a wahl pro series rechargeable. There are two screws, large blade, small blade, white plastic part and a silver bracket that seems to slide on the white plastic part. What goes in first? How do I assemble it? How do blades match? Do the grooves on large blade fit into small blade? Help, I can't reassemble it. Thanks in advance! Pam
May 06, 2009 | Wahl 8550
Wahl 8550 Logo
841 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
