Question about Malber P21 Front Load Washer
Malber P21 - works slower and slower
Hi, my washer is 7 yrs old, and has been working perfectly until a week ago. Now whenever it washes (on any cycle), it takes 3 times longer than usual, it sounds like it is pausing and stopping and "thinking" of what to do next. What can be the problem? I have never had the machine serviced before.
  • Anonymous Mar 18, 2014
    Machine 13 years old, has provided perfect service until now. Washing is still in machine and completed cycle. Door won't open.
  • 566 Answers
Hi from uk from what you describe /symptoms this is sure to be the motor brushes are worne very low and req renewing this is not beyond the d i y novice and the 2 x brushes for the motor here in uk cost approx £5 and easy job to renew if you remove rear panel off machine then remove motor you will see how it looks and secures just like a car alternator and also belt adjustment is same the brushes will be self explanitary of how they are renewed once motor is removed ? hope this helps/inspires you and will save you $$$$s by diy
Posted on Dec 19, 2008
My washer skips the last spin drain? It ticks from 5 to STOP very quickly and clothes are still dripping wet.
Time to replace your timer sounds like you have a mechanical timer not too difficult to do.Work safe.
Dec 03, 2014 | Malber P21 Front Load Washer
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
http://www.ajmadison.com/cgi-bin/ajmadison/P21.html
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email INFO@MALBERAPPLIANCE.COM.
Oct 17, 2014 | Malber P21 Front Load Washer
My malber washing machine p21 will not turn on it is making a clicking sound but nothing else
It might be due to the switch problem or wire will be cutted for that which runs the engine... Check the wiring and switch on the machine..
Thanks
Apr 01, 2012 | Malber P21 Front Load Washer
No spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 21, 2010 | Malber P21 Front Load Washer
I NEED A NEW HOSE " Y - INTO ONE. WHERE CAN A GET ONE? I HAVE A MALBER P21.
I'm a general contractor. I made up a new hose by using various couplings
and a speedy connector.
Jun 25, 2009 | Malber P21 Front Load Washer
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
Water leaks from bottom
IT SOUNDS LIKE YOU HAVE A BAD POINT IN THE TIMER,YOU CAN TAKE IT OUT TO SEE IF BURNT OR WORN,ALSO YOU CAN LEAVE PLUGGED IN AND WITH A PIECE OF PLASTIC NOT METAL PULL DOWN ON EACH POINT TILL YOU FIND THE BAD ONE,THANKS-MIKE
May 29, 2008 | Malber P21 Front Load Washer
My washer doesn't spin
check the drain motor working or not , if it is working change the power circuit board
Jan 07, 2008 | Malber P21 Front Load Washer
My washing machine won't fill with water
I have my washer connected to the kitchen sink. In order for it to fill I have to connect the hose to the faucet and turn it on, it is pain but that is the only way it will work for me. I hope this helps.
Sep 15, 2006 | Malber P21 Front Load Washer
Malber P21 Front Load Washer Logo
130 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
