Question about Hitachi 46F510 46" Projection HDTV
Power makes a sound but does not power up
I have a hitachi CT5582K projection tv about 50 something inches, it just stopped working. When I hit the power button, I hear a sound like the speakers, but the power light doesnt come on nor does the picture. I was hoping there was a reset button or something as this happen as a result of unplugging and moving. HELP I have big screen blues :)
robert
SAME PROBLEM AS YOU ROBERT! Same TV and same problem after pluggin in something else in another outlet. Did you ever solve this issue?
Please e-mail me at yanalou at aol dot com.
Big Screen Blues II
LOU
Posted on Sep 05, 2009
I have a 1994 50ex8k hitachi rear projection tv that wont turn on
it has a built in safety. there's a problem with tv board
May 31, 2010 | Hitachi Televison & Video
I have a Hitachi 50EX8K projection TV that will not turn on. When you hit the power button you can hear a "click" but nothing happens. I have some electrical knowledge and could use some help pointing me...
if this is projection tv that clicking sound it could be the ballast tryin to turn on a burned out lamp or the ballast could not be sending the right amount of voltage for ignition, you can check the ballast if its liking oil or if you see something burned in the board.
Apr 15, 2010 | Hitachi 50GX30B 50". Rear Projection...
48 inch Hitachi rear projection tv picture goes out.
Backlight main video board is going,video board must change,about $500 with labors.
Oct 10, 2009 | Hitachi 50UX57B 50" Rear Projection...
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
Probably a 'cold or detatched' solder joint on a component on that perticular circuit board you are 'wedging' with a plastic rod.
Apr 16, 2008 | Hitachi 43UWX10B 43" Rear Projection...
the best thing 2 do is buy a new one and get guarnteed with it again
if u try 2 fix it it not 50% working
if u got guarnteed then take it back (or phone them to come)
Nov 07, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
you have lookse connection on the video convergance amp ic
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 04, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Surround Sound Installation
The Hitachi 50UX57B is a 50 inch standard projection TV with a standard screen. It is not HD ready. If you need it, I think I can download the owner's manual (in PDF format) from Hitachi and foward it to you.
Aug 03, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 50 inch Rear Projection Color problem
Which sounds like a loose connection in the video or chroma section. you can carefully tap around affected area with a rubber screwdriver handle(not metal part) and see if it does come and go and look in that area for loose connections that needs soldering back. Hope this helps
Jul 30, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 46F510 46" Projection HDTV Logo
107 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
