Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Poor printing My printer was in storage, not used for a long period of time. I changed ink cart. and tried cleaning the heads several times. It prints out, but its not the way its supposed to look. Is there something else I can do, or does it need to be serviced professionally?
  • 284 Answers
Yes when you have left your printer in storage the ink tends to dry out, its cheaper to buy a new printer, taking it to a service professional might be costly, more than whats the printer is worth.
you can ask around not very many places do head cleaning. and check on how much, since they will spike you for parts and other stuff.
Posted on Dec 06, 2008
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Dec 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
New ink tanks for I960 - pics have a green cast...head check indicates magenta and photo magenta not printing. Have already tried cleaning and deep cleaning????
This printer model has a print head seperate from the carts. Over time, the print head can become clogged. Try removing the print head assembly from the printer and dipping just the printhead (the silver thing on the bottom) into a shallow dish of just boiled water several times. Dry off, reinstall print head and carts and try again. My need to do a few times. This will get rid of any congealed ink on the print head. Otherwise, new printer, as the replacement print head is more expensive than a new printer. Canon kind of made these disposable. Can also try to inject water through the cartridge port when the printhead is out of the printer ( the hole where the cartridge goes into) with hot water as well...
Aug 08, 2009 | Canon I960 InkJet Photo Printer
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
Cyan will not print
Try replacing the cartridge. Sometimes they do get clogged and won't clear no matter how many cleaning cycles you run.
Mar 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Brother MFC-440CN won't print color
Did you use generic carts?
Do use only original brother ink carts!
Only these have special cleaning fluids mingled with the ink.
There are several advantages, too:
You can run a special cleaning mode (DO insert original carts at first!!!)
Press menue then start bk copy then fourtimes arrow-up.
machine should switch to maintenance mode (buttons will flash).
press 7 then 6 then 4 then start bk copy. machine will refresh ink within the tubes and the print head and run a special cleaning routine. when finished press 7 then 6 then 3 then start bk copy to run a power cleaning. leave the maintenance mode by pressing 9 then 9.
The machine should print without proböems. If there is a poor quality left, the printhead is affected by bad ink and cant be fixed anymore.
Jan 24, 2008 | Brother MultiFunction Center MFC-440CN...
Not printing in color
Chances are the tubes are clog and you need to dismantle the printer to clean it, if you have tried cleaning the heads several times then nothing change. Might as well have it service or buy a new one, call epson customer service- 562 276 4382 or 1300 so that they will offer you the loyalty website and you can get a new epson printer, discounted in price.
Hope this help
Nov 03, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Poor printing
With printers $23 at Wally world these days its not fessible to repair this age of printer. The problem we have with customers here locally is the same thing. We ask them "How old is the ink?" They reply "Its new!" then come to find out later that its new to them cause they bought it 6 months ago and havent used it since. Well typically if this is a cartridge printer eg:the tank and head is one unit, change the blasck cart. IF it has seperate heads change the black print head it has probable reached the end of its life, but the thing with the heads is there typically $30-$70 each which its more feesible to go get a new unit.
Sep 14, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Printing problems after changing Cyan and Magenta cartridges
Try cleaning the contacts and cartridge sensors as well as the cartridges. Try deleting the printer settings and reinstalling. If you?re printing high res. Set the printer to default, and try printing again. Hope it works out
Feb 21, 2006 | Epson Stylus CX5200 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
