Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Printer problen I have a Xerox WorkCentre XD125f printer that is showing the error as H4. What does that mean.
  • Daryl Marples Feb 03, 2007
    Nothing at all seems to happen with this machine. It reads H the $ over and over and nothing else is possible. It won't alter reading or clear it just remains showing H the 4 over and over and NOTHING changes this. Suggestions please ? Thanks kindly M-101
How to take a scan from Canon iR2200-3300 pls help me regards this
Posted on Jan 21, 2009
  • ram_0110 Jan 21, 2009
    HOw to take a scan from Canon iR2200-3300
There is the complete procedure to reset this code:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=393,E=0000000000178244991,K=3206,Sxi=3,Case=obj(23198)
good look :)
Posted on Oct 22, 2007
    Novelist:
    Champion:
  • 202 Answers
Low Fuser Temperature. Probably a blown heat lamp try reseting the H code Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE. The display should go blank. Then enter 14 with the copy count keys and press START. If the machine does not turn off and back on by itself - then turn it Off and back on. See if the H code comes back. Tim
Posted on Jan 29, 2007
  • Timothy Higgins
    Timothy Higgins Feb 03, 2007
    Funny...I found that info on the XEROX site tech notes.
  • Timothy Higgins
    Timothy Higgins Feb 04, 2007
    Question:
    I get an H code on the LCD panel, How can I fix this?
    Answer:
    1. Turn the power to the copier OFF.
    2. Make sure the copier is in a dedicated outlet and not a power strip or surge protector.
    3. Turn the power to the copier ON. (If code remains proceed to step #4).
    4. Turn the power to the copier OFF for 30-60 minutes to allow the copier a chance to cool. Open the copier up as if you are going to remove a paper jam and locate the Fuser Assembly. (See Figure #1)
    Figure 1
    5. Reseat the fuser lamp between the copper "L" shaped bracket, making sure the white tips of the fuser lamp are seated squarely and securely between the brackets. (See Figures #2a and 2b)
    Figure 2a
    Figure 2b
    6. Close the copier up. Turn the power to the copier ON. If the code remains, contact Xerox Support via E-mail for further assistance.
    Question:
    What if my copier displays an H code?
    Answer:
    Follow the instructions below.
    1. Turn off your copier.
    2. Make sure your copier is connected to a grounded wall outlet and not a power strip or surge protector. If the code remains proceed to step D.
    3. Turn on your copier.
    4. Open the copier as if you are going to remove a paper jam and locate the fuser assembly.
    5. Reseat the fuser lamp between the copper L shaped bracket, making sure the white tips of the fuser lamp are seated squarely and securely between the brackets.
    6. Close your copier and turn it on. If the code remains, order a Fuser Lamp Kit.
    http://www.xerox.com/xrx-search/MainSear...
Need Win 7 Driver For Xerox Workcentre XD 125F
you can't find one. What you can try is install an older driver or a standard printer driver. that might give you some functions
Dec 08, 2013 | Xerox WorkCentre XD125F All-In-One Laser...
How do i fix an H4 error message?
That code, H4 is a fuser temperature error. You can just replace the fuser 126N00181 yourself.
Whit Item, Inc.
Dec 08, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
After turn it on, the display Shows "H", "4" alternatively, and the XD125f machine does not work. No pre-heating. What is wrong? Thanks a lot for your help! Steven
To reset the H4 condition on your XD125F series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Good Luck and Thank You for using Fixya.
Sep 05, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
What does the error code J1 mean?
This means its time to replace the Toner cartridge.
Oct 07, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
J2 ERROR
Replace the Drum Cartridge.
Jun 26, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox Pro16fx - H4 Error Massage after power outtage
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=473,E=0000000001213816584,K=3906,Sxi=8,Case=obj(6116)
Feb 02, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox Workcentre Pro16fx - H4 error code after power outtage
You shut the machine off then on, Press Clear, auto,clear , auto, then when the lights go out, program it as if you were running 14 copies. press start and that should reset it.
Thats the redish pink clear button and the auto exposure button, Clear, Auto , clear auto, and the display goes blank , enter 14 and start. Dont ask me why I repeated that LOL
Feb 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
H4 message call service
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
May 27, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox Workcentre XD125f problem
Does it keep showing that after you replaced the toner cartridge?
Aug 17, 2007 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
240 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
