Question about Comet GXD2527G Pressure Washer Pump
Removing and installing seal kit in Comet pump
I have purchased a seal kit for my Comet pump 3530. Can anyone give me some tips on removing and replacing the seals in the manifold without inflicting any damage? Do I need a special puller?
  • David Ford
    David Ford May 11, 2010
    If this is like the pressure washers I used to work on all you have to do it remove the caps and the seals and springs are underneath and cal be pulled out by hand or a small screwdriver can be used to remove them. If this is not the case let me know and I will do more research. Good luck
Install crankshaft kit on 2004 hyundai sonata 6 cylinder 2.7l engine
Really need more information...It sounds like they didn't give you a complete gasket kit...You will have to remove and re-install other components just to be able to see the crank shaft....You need the front and rear oil seal for the crank..,Oil pan gasket..,exhaust will have to be removed also...etc.......NEED MORE INFO..
Jan 24, 2015 | Hyundai Motor 2004 Sonata
Oil seeping from Comet BXD 2525 pump
out the drain plug ? Sight glass window ? Under the pump where the crankcase meets the pump head?
tighten plug, replace oring on sight glass or replace low pressure seals if near the pump
Dec 09, 2013 | Comet BXD 2525 G Pressure Washer Pump
Comet water oil
You have to take off the pump head. Here is the link to the service for comet pumps.
https://www.pwmall.com/PDF/CometServiceManual.pdf
Nov 03, 2013 | Comet GXD2527G Pressure Washer Pump
Comet axd 3020 will not build pressure
junk axial wobble plate pump. Usually axial pumps are not worth the time to try to fix them. This one has a 5 year warranty , so they think they have a pretty good one. ( I would never buy one) If you want to try to fix it, I would check the check valves first. Take them out and see if some are broken or not sealing properly. There is a valve kit available.
The other likely problem is your unloader valve. If the seal is shot or the valve stuck open the pump will not build pressure.
parts diagram http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/axd-PUMP%20BREAKDOWN.pdf
Oct 31, 2013 | Comet Garden
POWER STEERING PUMP OVER FLOWING
this is normally caused by a broken seal in the power steering rack or the pump itself.. there are 3 ways to repair this..
1.) purchase a seal kit from a dealer and have a local mechanic change the seals for you,, he will also tell you which kit to purchase .. (cheap effective way)
2.) get a replacement from a scrap yard,, might cost a bit more but its faster,, and any mechanic will be able to replace it..
3.) purchase a new one from a dealer.. (expensive)
now your predicament is if its the pump or rack.. I'm on the pump,, but a broken seal in the rack can cause the fluid to back flow.. but more than likely its seals in the pump..
Jan 12, 2011 | 2001 Dodge Ram 2500 Truck
I have a Comet 4040 and oil and water mix is bubbling out of the red cap on top of my pressure washer. Can anyone tell me what repair kit I might need to fix this problem?
Hi this could be the oil and pump seals worn. Also make sure that you don,t have the transit plug in or the pump cannot breath. It should have a air vented dipstick.
May 21, 2010 | Comet GXD2527G Pressure Washer Pump
Assembly
HI your machine would have been delivered with a blanking plug in the pump. You will need to remove this and fit a vented pump or your pump will build up too much pressure inside.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
What kind of oil do I put in my Comet AXD2524G-T pump?
If the Comet Pressure Pump Oil is some kind of a
Synthetic Oil that supposed to be extra effecient than
an ordinary oil, then that will cost extra. If that is ordinary multi grade engine oil (SAE 20 - 40), then, you
can buy over the counter. Most synthetic oil have additive that give extra longer life to all moving parts.
Nov 27, 2009 | Plumbing
Comet 2.5 Gpm pressure washer pump wont **** soap anyone know what you have to do to make it start sucking soap
I have found many comet pumps to be plumbed wrong from the factory. Look on the side of the soap injector and look for the flow arrow, make sure its in the right direction. If it has worked in the past,then take it apart and replace the spring, check ball and seat.
Nov 03, 2009 | Comet GXD2527G Pressure Washer Pump
Oil Leaks
I did an engine swap because of a rod knock and when I removed the power steering pump the seal was upset and would not seal again. I found a guy on the internet who had a kit for under $75 shipping included (sorry can't remember sight name). This kit comes with a new improved two lip seal, couple o-rings, gasket, home made tools, and a video showing how to install the new seals. I installed the kit and it fixed the leak in about 3 hours. The dodge dealer wants $1100.00 for a rebuilt vacumme pump. Do a google for power steering leak.This is a very common problem even for a pump that has not been removed.
Feb 07, 2009 | 2001 Dodge Ram 2500 Truck
Comet GXD2527G Pressure Washer Pump Logo
739 people viewed this question
Top Comet Garden Experts
michael
michael
Joseph Hoffmann
John Trevino
Are you a Comet Garden Expert? Answer questions, earn points and help others
