Question about Whirlpool GH7155XHS Microwave Oven
Buttons #3 & 8 on control panel not working
Whirlpool model gh7155xhs-1000 watts microwave. problem started with buttons #3 and 8 and now the fan has also stopped working.help!!!
  • Whirlpool Master
  • 9,086 Answers
Sounds like your keypad has failed and you need the fan circuit repaired on the control panel.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Add to that about $75 for the keypad.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 02, 2008
GH7155XHS Microwave control panel
If you do not want to get the newer model due to configuration changes it does not appear that you have another alternative other than to replace the logic board on unit. And unless you can spot a very obvious issue with the board, there is no way for you to fix it especially if it is a bad ic with beaucoup connections to the board.
Mar 24, 2017 | Whirlpool GH7155XHS Microwave Oven
GE spacemakerXL microwave JVM1650 w touch screen Hi speed not working on external vent fan
It seems like the control panel is malfunctioning. The censorfor external vent fan may not work due to faulty control panel. You need toreplace the control panel, so that microwave will work properly. Replacing anERC is not a difficult repair and can be accomplished by the average do-it-yourselfoffer. Hope this will help you. Good Luck.
Aug 06, 2011 | GE JVM1650 1000 Watts Microwave Oven
What are the dimensions of the Whirlpool microwave GH4155XPB?
Dimensions/Weight Exterior Dimensions (WxHxD): 29 15/16" x 16 1/4" x 15 7/16" Cavity Dimensions (WxHxD): 22 3/8" x 8 3/16" x 13 13/16" Approximate Shipping Weight (lbs.): 86 Microwave Capacity (cu. ft.): 1.5 Cooking Power (watts): 1000
Jun 06, 2011 | Whirlpool GH4155XP Microwave Oven
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
Whirlpool GH7155XHS microwave shows partial display
The display is defective and requires replacement. Unfortunately, the display is probably incorporated as a unit with the control panel and must be purchased as an entire service part. This will cost $80-$120 depending on the oven make & model. It will cost more if you have a repairer install the part.
It may be more cost effective to replace the oven. Microwave ovens are rather inexpensive these days.
Mar 06, 2009 | Whirlpool GH7155XHS Microwave Oven
PCB repair
Yes we can.
Feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
Before you power it back up after the repair, you should double-check the wiring of the switches against the "mini-manual".
It's located behind the grille or below the circuit board.
If you don't find yours, you can download it here.
William E. Miller
prototech@usa.net
Feb 03, 2009 | Whirlpool GH7155XHS Microwave Oven
Microwave dead
First, there is an outlet. Plug in something else. Inside the key panel, there are fuses and a thermo sensor. Either may be bad. The thermosensor is about the diameter of a dime, black and 3/8 inch thick...attached to the wall of the chamber. All should have continuity.
Dec 20, 2007 | Whirlpool GH7155XHS Microwave Oven
Some buttons work, some don't.
The keypad may be bad. Most often they go bad due to moisture from cleaners being sprayed directly on them or steam from the cooktop when the vent fan is not used.
They can also go bad when the unit is stored in an unheated environment where there's a lot of air temperature change (hot during the day, cold at night, etc.)
It may also be some residue on the connections where the keypad plugs into the control board. Unplugging then replugging the keypad can sometimes clean them.
In other cases, a new keypad is needed.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 07, 2007 | GE JVM1850 1000 Watts Microwave Oven
Whirlpool GH7155XHS Microwave Oven Logo
114 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
