Question about Daewoo DSJ-5510CRA 55" Rear Projection HDTV-Ready Television
Standby light comes on but TV won't when turned on
Daewoo model DSJ5510CRA manf 2004 No picture or sound when TV is on ready and you press the power button Please help Thank You
    Problem Solver:
  • 4 Answers
I am having the same problem. Have you had yours repaired yet?
Posted on Jan 02, 2012
How can i repair a tv that turns on but has no picture or sound
Have you tried a factory reset? I had a similar problem my TV was stuck on standby (red light only) I did this
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
and it worked!
Oct 16, 2015 | Sony KDL46EX400 46 in. HD-Ready TV
Blue light comes on but tv won t turn on no picture or sound nothing works
The blue light merely indicates power is getting to your TV. The internal power supply may have failed.
Aug 15, 2014 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
2004 rear projection daewoo tv problems
No value used, no one wants this old technology anymore.
May 18, 2017 | Daewoo DSJ-5510CRA 55" Rear Projection...
I Have 2004 43' inch Daewoo model DSJ-4710CRA will power on but cuts right back off any fixes?
I see so many here with no sound/nopicture issues:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Mar 30, 2012 | Daewoo DSJ-4710CRA 47" Rear Projection...
37PF9731D/10 - when turned on the tv power light remains green but no picture or sound. Just a clicking sound - like it does normally when swiching on from being on standbay. It reapts the attempt to turn...
The clicking sound is from the main power supply relay being turning on and off, it is driven by hte main board and it gets the power from the standby power supply board.
You need to check the main powwer supply board and the standby power supply board voltages.
Check the resistor in the main power supply board also
Please see my pictures here:
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 16, 2011 | Philips 37PF9731D 37 in. HD-Ready LCD...
I have a 51 in. Sony model kp-51ws520. when I turn tv on I get sound by no picture. Standby light blinks 5 times then shuts off . If I power it back on, sound no picture then standby blinks 10 times after...
Ck small blue capacitor next to hori output Transistor 2k volts they have been known to go Bad, if its OK replace Both of your STK ICs STK392-110s use 180s Mats has them 1-800-628-1118
Mar 23, 2010 | Sony KP-51WS520 51" Rear Projection...
Daewoo Plasma dp-42sm
Just answered this on a different one. I have the Daewoo Plasma Digital Dream model dp-42sm, My dads tv expert friend looked at it and told us the ysus board was out. I got on ebay and bought the item from a store for 125 dollars used tested good with 12 dollar shipping, I put the part in myself it was very simple just take your time dont try and rush you have to take the actual bar the stand hooks onto off and the 2 boards going into the ysus board. It fixed the problem and is still in working order im using it now as the computer monitor.
Feb 28, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
Dec 22, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
Trouble Turning On
is this a lcd projection or just tube projection
Nov 15, 2007 | Sony KP-46WT500 46" Rear Projection...
Daewoo DSJ-5510CRA 55" Rear Projection HDTV-Ready Television Logo
214 people viewed this question
Top Daewoo Televison & Video Experts
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
