Question about Kitchen Ranges
The front of my Kithcen Aid stove was broken. Model # on the electric built in range is YKEBS177YW1. Apparnetly Kitchen Aid has been taken over by Whirlpool the new model # is 814569 or I can use 3185474 each of these numbers to be preceded by 22880. Can I cook without the front glass? Apparently it cannot be shipped from the States for 3 weeks. Yikes!!! I need to cook before Christmas. Any ideas how to get a new glass front for this stove?? Thank you soooo much for any assistance
  • 78 Answers
If this is just outer glass you can cook for short period of time.
I'm not sure what color is your front glass but I can give you few sites it should help:
http://www.marcone.com/
http://www.partselect.com/
http://www.repairclinic.com/
They all have 800 number
Posted on Dec 02, 2008
Why is the neutral not hooked up on my stove
If you are using an electric Kithcen Range, most probably it is working at 220V and necessarily shold have a so called "earth" or "neutral" line. If it doesn't, your electric system is not installed correctly.
If you don't have the knowledge how to make a correct connection, you should call a qualified electric repair service
How to Install New 3 Prong Range Cord On An Electric Stove
Under cabinet Range Hood Installation New version
Aug 13, 2015 | Kitchen Ranges
Problem with Kitchenaid Electric Range Stove Top Burner
there may be a loose connection in either the pipe or on the burner rings on the surface. Some stoves have a safety cutoff if gas supply is interrupted to avoid prolonged gas supply.
May 12, 2012 | KitchenAid KERA807P Electric Kitchen Range
I have kitchen aid in the counter range, the bottom heat element is bad. The element has burnt and has a 3" piece that has separated. At the same time the oven stopped working the burners stopped working...
The oven element will not affect the top burners, Unless it tripped the breaker at the panel when the element burned it two. Is there power to the stove? The top burners have their own power and control separate.
Aug 01, 2009 | Kitchen Ranges
Kitchen aid electric stove does not go on
check the door lock switches on the door lock they get bent out of sdhape real easy
Jun 29, 2009 | KitchenAid KERC607 Electric Kitchen Range
Large element burns high
The problem is in the switch not the element.
Mar 24, 2009 | KitchenAid KERC507 Electric Kitchen Range
Kitchenaid Oven won't work E0 F2 on the control pad
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Jul 24, 2008 | KitchenAid KESC307 Electric Kitchen Range
Cannot shut off the kitchen aid stove with the "Off" button, model # KESA907PSS01
i had the same problem with mine.. i overboiled some water and it leaked down the front onto my panel (inside).. i had to replace the whole thing.. (i did it so i added a silicone bead inside so water cannot get to that same panel area)..
3 years and it still works..
replacement panel is about 120.00 CAD
Jun 26, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
110 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
