Background Music I am trying to use your program, how do i add multiple background music
  • David Lagesse
    David Lagesse May 11, 2010
    What? I do NOT own any programs!
    I recieved this email from FixYa:
    Dear Kawika-56,
    valerie_alic has posted a request for you.
    Click here view your Request.
    Regards,
    The FixYa Team
    What program are you refering to?
    Try submitting this again.
Slow buffer/shutter during music play and video play
Background running programs must be the reason for that you must use some start up manager or background application manager to avoid such type of problems, The one well known and reliable program is Reginout to manage everything on your PC & will secure your music from lagging or shuttering. Thanks
Feb 06, 2014 | Acer Aspire One AOA110-1113 Netbook
I was cleaning my phone and I pressed on something and now there is music playing that i can not stop,I don't know how to stop the music,my phone is panasonic KX-T7730
Here are two methods to turn off background music, one of these should work depending on which Panasonic phone system your phone is connected to.
1) With phone idle, press the 1 key on the dial pad (turns off background music when it is on and turns on background music when it is off).
2) With phone idle, press intercom button then dial *751 on the dial pad followed by 0 on the dial pad to turn off background music(confirmation tone will be heard) and end by lifting handset and replacing in cradle. To turn background music on, press intercom button then dial *751 on the dial pad followed by 1 or 2 on the dial pad to select the background music source(confirmation tone will be heard) and end by lifting handset and replacing in cradle.
Feb 05, 2011 | Panasonic KX-T7730 Corded Phone
Howcan i add a background music on my friendster?
I contacted the guys at http://www.informationzoo.com/Friendster.html and they did it for me for free.
Jul 03, 2009 | Profile BS-12 Car Subwoofer
The background music is louder than the voices
try resetting the equalizer in your wm player...
May 22, 2009 | Microsoft Windows Media Player
Need correct procedure for installing and programming voicemail on a panasonice 308 ccu
Here's a link that will get you the manual, wiring diagram and specific help on these phones.
http://www.htcnetworks.co.uk/Panasonic%20KXT%20206,%20308,%20616,%201232,%207000.htm
Hope this helps.
Mar 29, 2009 | Panasonic Lands Phones
Offing the background music
Walk up to the phone, don't pick up the handset and press "1". If that doesn't work, try *7510 on the intercom (taw tda).
Carl
Feb 25, 2009 | Panasonic KX-T7730 Corded Phone
Change background music when hold button is pushed
Your system will have an input for music. You may have something attached already and so that would need to be changed to what you want. OR you may be using a built-in internal tune. Usually connecting an external source will over-ride any internal music automatically but it may need to be changed in programming. If you connect a new external music system, you can use just about any music device with the right cable. Just make sure it is line-level input (low volume - not amplified) or you can break the music circuit.
Jun 01, 2007 | Panasonic KX-T7730 Corded Phone
No sound
Sounds to me like your center speaker is either not connected, or somehow not working. The not working part could be explained by a failed speaker or, possibly a failed amp in the unit.
Mar 11, 2007 | JVC TH-M505 System
Computers & Internet Logo
David Payne
David Payne
