Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
How do i replace a broken belt on a dc07?
Old belt snapped had a look underneath ,took guard off but couldnt see how to fit new one
  • stevel ock
    stevel ock Dec 07, 2008
    to advacak ,i have managed to strip and insert a new belt you were right it was an absolute nightmare NEVER AGAIN .....but worth it as teyre a damn good hover
  • 107 Answers
If you would like i will help you over a chat session.
It is a moderate task and i do them daily in about 20 minutes. First time took me 45.
Posted on Dec 09, 2008
  • 125 Answers
The vacuum must be completely torn apart to replace the belt/clutch assembly. be very careful as the parts will break easily
the assy you need runs around $60 or more at a vac repair shop
i have been in the repair business for 20 years, and the dyson is about the worst one out there
get yourself a Panasonic or a sanitair
Posted on Dec 02, 2008
Dyson DC07 belt change has resulted in very noisy vacuum!
Hi I agree with the first 2 solutions above but not the 3rd one.
If you have suction coming through the hose when the machine is in upright position then the u bend has nothing to do with this problem.
Right so ... The belt snapped.
The answer to you question is "why did the belt snap" its true that it could just be old age but its more likely to have been caused by a foreign object being sooked up.
How the belt/brushbar/motor interact
Your belt simply connects the motor to the brushbar know as Direct Drive. If an object get inside the space between the motor and the brushbar or if it can jam the brushbar then this will cause the rubber to burn. The motor will keep spinning and the belt wont be able to so will snap.
So its easy to see that the belt has snapped and people just think "'oh the belt has snapped"
You might wonder where im coming from here.
Anyway because the brushbar got jammed it may also have been buckled slighty either as a result of the foreign object causing it to stop suddenly from spinning at high speed or/and the result of the heat build up.
The rattling noise you now find your Dyson making is more than likely because your brushbar is buckled and when it spins the bristles are hitting the housing unit.
Your belt will snap again unless you replace the brushbar
Apr 10, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My DC07 belt snapped and there was smoke from the bottom. I replaced the belt and it just immediately snapped and melted again. Any suggestions?
Sorry to hear you're having a problem with your DC07. You should be able to resolve the issue by following these simple steps to check the brushbar and belt are correctly fitted, and are free of obstructions: http://www.dyson.co.uk/support/help.asp?article=18&product=DC07-SY
If you're still experiencing difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Apr 08, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a dyson dc07 the belt breaks all the time and the whole brush has just snapped underneath ?
There appears to be an issue with parts connectoed to the belt and brushbar. This iscaused the belt to stick and the heat from this has caused the belt to break adnd also eventually caused the brushbar to melt
Mar 07, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Roller is not spinning and picking up. Can you help?
I had a similar problem, the belts were worn, i replaced them and it works fine.
Feb 20, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Have a dyson dc07 -roller bar broken. have
It always feels like something must break as it's a really tight fit, but go to www.dysonmedic.com then scroll to the bottom of the page and click on DC07 belt and brushroll replacement guide. You'll find everything you need there. Good luck!
Jan 24, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Filter Release Catch removal
if its the part im thinking of its a small spade like catch thats glued into a hole in the chassis normally id lay the machine on its front and gently tap the old catch out with a flat end screwdriver and a small hammer be carefull its very brittle
Nov 11, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Broken belt
Hi.
If you cant easily see how to replace the Belt then I think your Dc07 has A clutch unit.
This type of Dc07 has 2 belts one from motor to clutch & the second belt goes clutch to brush roller.
You will need to remove the clutch unit completey from the machine in order to replace the belts, Its alot to explain so try this site it has service manuals covering this.
http://dysonmanuals.llc.nu/
Jul 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson 07 beater bar doesn't rotate
Hi.
If your Dc07 is all floors it will have A clutch fitted this is easy to determine just stand in front of your machine look down at the left hand side there will be a coloured knob on the side e.g. blue.yellow,green,purple this will have a pointer on it which when you pull handle back to vacuum must move to drive position you can rotate it by hand if it is stuck in park position ,
If there is no belts broken the brushes will now turn.
If they don’t the chances are one of the 2 belts have snapped.
You will then need Manuals to help you repair the problem.
Go to this site for more infomation.
Chris..
Feb 12, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc07 motor sparks
Hi.
I think you are looking at replacing the motor with a new one.
Chris..
Dec 30, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
108 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
