Question about Lexmark Computers & Internet
Can not copy from word pad - Lexmark Computers & Internet
    Sergeant:
    Champion:
  • 272 Answers
Try this. Hold down Control and C at the same time as you hi-light what needs to be copied.
Posted on Dec 02, 2008
SERVICE MODE
From the manual I have
1. Press the power pad to turn on
    press home pad to ensure home screen is displayed
2. Press the help pad. the main help screen is displayed.
3. Press the help and start stop pads for 3 sec simultainiously.
    The factory test screen is displayed.
4. Press test load on the screen.
5. The contrast screen is displayed. Press the start/stop pad once to cycle through the screen
6. press start/stop pad. The test load screen is displayed.
More to come... I will try to copy and paste what it says. I can try to send a copy of the pdf if you give an email.
Oct 19, 2007 | GE WPGT9360EPL Top Load Washer
The waste ink absorber is almost full
Follow the steps to fix the issue.
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3)SET ABS-M LEVEL TO 0
4)OK
Or the steps below.
To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
There ya go MP130 up and running again.
Regards,
Ron
Feb 25, 2011 | Canon PIXMA MP130 All-In-One InkJet...
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
The waste ink absorber is full
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Jan 04, 2011 | Canon PIXMA iP90 Mobile Printer
Pixma MP/130 Waste ink absorber almost full. How do I fix it please?
Use arrow keys to scroll to “Service menu counter access”.
Press OK.
Use arrow keys to scroll to “ABS-M DOT COUNT”
Press Copy.
Press OK.
Press Stop/Reset.
Apr 06, 2010 | Canon PIXMA MP130 All-In-One InkJet...
My x box wont read any discs
Greetings,
Please go through the Website link mentioned below.
http://support.microsoft.com/kb/816779
Note 1 If a saved game file is corrupted, it can produce a disc error message in that game, particularly when the game starts. You can resolve this issue by deleting all saved game files for the affected game from the Xbox hard disk. This method is effective approximately twenty-five percent of the time. If you experience this disc error message with more than two games, this procedure will likely not resolve the issue.
Note 2 Do not use laser lens cleaners, or similar products. Microsoft has not determined the effectiveness of these products or the affect they may have on the Xbox system. Microsoft cannot promote or recommend any type of laser lens cleaner for use with the Xbox system.
1. Clean the disc and examine the disc for flaws or scratches
Hold disc by the edges without touching the surface with your fingers.
2. Clean the disc with a soft, clean cloth, lightly wiping from the center outwards.
3. Do not use solvents or chemicals to clean the disc.
4. After you clean the disc, examine the disc for any scratches or defects. If you find any defects that are not caused by typical wear and tear, return the disc to the retailer if it still under warranty.
Copy and delete any saved games from your hard disk
Note To copy saved games, you must have an Xbox Memory Unit (MU). You must copy saved games to a MU before you delete them.
1. Start your Xbox console with no disc in the disc tray. The Xbox Dashboard appears.
2. On the Main Menu screen, press the directional pad (D-pad) up or down to select Memory, and then press the A button.
3. On the Memory screen, press the D-pad up or down to select Xbox Hard Disk, and then press the A button.
4. On the Xbox Hard Disk screen, press the D-pad up or down to select the game title you want, and then press the D-pad left or right to select the saved game you want to copy.
5. On the Copy/Delete screen, press the D-pad up or down to select Copy, and then press the A button.
6. On the Copy To screen, press the D-pad up or down to select the memory unit you want to copy to, and then press the A button.
7.Press the B button to return to the games list on the Xbox Hard Disk screen.
8. On the Xbox Hard Disk screen, press the D-pad up or down to select the game title you just copied a saved game from, and then press the A button.
9. On the Copy/Delete screen, press the D-pad up or down to select Delete, and then press the A button. You receive the following message:
Are you sure you want to permanently delete this saved game?
10. Press the D-pad left or right to select Yes.
11. Repeat these steps for each saved game on the Xbox hard disk. If you have many saved games but you can remember when you started to receive the disc error message, you can just delete the saved game files that you created after that time.
Back to the top
Please let me know if you have any issues.
Regards,
Feb 11, 2010 | Microsoft Xbox 360 Console
MULTIPLE FEED PROBLEM
There is a little with pad that is called the seperation pad. You can see this under the pick up rollers. Clean this off with some alchohol. It may fix the problem. If not a new pad is needed.
Speration pad needs cleaned or replaced. Its a $10.00 part.
Jan 09, 2009 | Canon PC1061 Copier
Riso
probably needs a new adf stripper pad.. the first little rubber pad on the bottem of the inside of the adf
Aug 11, 2008 | Riso RZ220 Duplicator
Ink waste absorber is full, what do i do!!!
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Mar 15, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Computers & Internet Logo
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Robert Monigold
Robert Monigold
micky dee
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
